MHB Find the values of the parameter "q"
  • Thread starter Thread starter anemone
    Parameter
The discussion focuses on finding the values of the parameter "q" for which the equation has exactly three distinct real solutions. The solutions identified are q=9 and q=34. The approach involves rewriting the equation and analyzing the discriminants of the resulting quadratic factors. A key insight is recognizing that a repeated root can occur once in each factor, leading to the additional solution q=34 when both factors equal 136-4q=0. The conversation highlights the collaborative nature of problem-solving in mathematics.
anemone
MHB
POTW Director
Hi MHB,
Problem:
Find the sum of all positive real values of the parameter $q$ for which the equation $(x^2+4x+4+136)^2=16q(5x^2+4x+136)$ has exactly three distinct real solutions.
Answer:
$q=9$ and $q=34$.
I am aware the question is actually asking us to find all possible values of $q$ when the given quartic equation has one repeated real root, and two other distinct real roots.
Attempt:
The original equation $(x^2+4x+4q+136)^2=16q(5x^2+4x+136)$ can be rewritten as
$(x^2+4x+136+4q)^2=16q(4x^2+x^2+4x+136)$
If I let $k=x^2+4x+136$, the equation above becomes
$(k+4q)^2=16q(4x^2+k)$
Expanding both sides of the equation and then rearranging them as a quadratic equation in terms of $k$, we have
$k^2+8qk+16q^2=64qx^2+16qk$
$k^2-8qk-64qx^2+16q^2=0$
$(k-4q)^2-16q^2-64qx^2+16q^2=0$
$(k-4q)^2-64qx^2=0$
$(k-4q-8x\sqrt{q})(k-4q+8x\sqrt{q})=0$
Replacing the expression for $k$ back into the equation above, we get
$(x^2+4x+136-4q-8x\sqrt{q})(x^2+4x+136-4q+8x\sqrt{q})=0$
And in order to satisfy the requirement set by the problem and to find all possible values of $q$, we can do so by equating the discriminants of the quadratic factors, one after another and we should expect two $q$ values to be found.
Hence, by equating the discriminant for the first factor $x^2+4x+136-4q-8x\sqrt{q}=0$ to zero, we obtain:
$(4-8\sqrt{q})^2-4(136-4q)=0$
$\sqrt{q}=3$ or $\sqrt{q}=-2.2$ and since $\sqrt{q}>0$, we get $q=9$ as one of the solutions.
Now, if we set the discriminant of the second factor as zero, we get:
$(4+8\sqrt{q})^2-4(136-4q)=0$
$\sqrt{q}=-3$ or $\sqrt{q}=2.2$ and since $\sqrt{q}>0$, we get $q=4.84$ as the other solution.
I checked the answer when $q=2.2$ and we would only get all 4 complex roots if $q=2.2$ but with $q=9$, everything is fine as is.
My question is, I don't know how to find the answer where $q=34$...any ideas?
By the way, I know there must be other ways to approach this problem, so if you don't wish to go through my silly attempt, I welcome you to post another method to solve the problem and I will appreciate whatever help that you are going to offer me.
Thanks in advance.
Mathematics news on Phys.org
anemone said:
Problem:
Answer:
$q=9$ and $q=34$.
$\vdots$
... we get
I had to spend over four hours in trains today, going to and from a meeting in London, and I spent all that time struggling with this problem. I got close to a solution, but your approach is far neater than mine.
The missing solution comes this way: In the equation $(x^2+4x+136-4q-8x\sqrt{q})(x^2+4x+136-4q+8x\sqrt{q})=0,$ you looked at the case where the repeated root comes in the first of the two factors, and when it comes in the second factor, but you overlooked the possibility that it might come once in each factor. That can only happen when the two factors are equal, and that in turn can only happen when $8x\sqrt{q}=0.$ That implies $x=0$, and the two factors then both reduce to $136 - 4q=0$, or $q=34.$
Hi Opalg,
Thank you so much for your reply.
Ah! I missed checking the likelihood that the repeated root might occur once in each factor and I wouldn't have thought of this if you hadn't pointed it out for me. I am so grateful that I can always depend on MHB to find for the missing part of the "math puzzle"!
When I read that you spent all the time sitting in the train struggling with this problem, it melts my heart so thoroughly. I hope there is a day where I can buy you a coffee (or tea, whatever that you would like to) or deliver one to your house, a cup of hot coffee that is specifically just for you! :D
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Thread 'Imaginary Pythagoras'
I posted this in the Lame Math thread, but it's got me thinking. Is there any validity to this? Or is it really just a mathematical trick? Naively, I see that i2 + plus 12 does equal zero2. But does this have a meaning? I know one can treat the imaginary number line as just another axis like the reals, but does that mean this does represent a triangle in the complex plane with a hypotenuse of length zero? Ibix offered a rendering of the diagram using what I assume is matrix* notation...
Fermat's Last Theorem has long been one of the most famous mathematical problems, and is now one of the most famous theorems. It simply states that the equation $$ a^n+b^n=c^n $$ has no solutions with positive integers if ##n>2.## It was named after Pierre de Fermat (1607-1665). The problem itself stems from the book Arithmetica by Diophantus of Alexandria. It gained popularity because Fermat noted in his copy "Cubum autem in duos cubos, aut quadratoquadratum in duos quadratoquadratos, et...
