Find the velocity and acceleration of a pulley in a mass-spring system
In summary: The total length of the cord increased by an amount equal to the distance the configuration moved multiplied by the tension in the string on the left, which is ##T##.
mattlfang
28
Given below system. We know the Hooke's constant of the spring is k. the mass of the box under the pulley is m. The mass of the pulley is M. The radius of the pulley is R. Radius of gyration is r
We release the system from the static state. When the spring is extended by L, what's the the velocity and acceleration of the pulley?
Radius of gyration, moment of inertia, conservation of energy
This looks like a classical setup but I can't find a solution. We can calculate the energy of the system by looking at the work done by the gravity and the spring. But how do we divide the energy between the kinetic energy of the pulley and the rotation of the pulley?
Likes Delta2 and Leo Liu
By assuming the string does not slip on the pulley. What relationship does that give you between the rotational velocity and the vertical velocity of the pulley’s centre?
Sorry I want to ask something, is radius of gyration the length of the string that connects the center of the pulley to the small mass?
No, it means the distance k s.t. moment of inertia is mk2.
Likes Delta2
So, @haruspex this problem can be solved with energy considerations only or we ll have to do it with forces and solve differential equations? Something tells me because it asks for the acceleration we have to do it with forces is that correct?
Likes Leo Liu
The velocity can be found by considering energy, the acceleration by considering forces. Neither requires calculus.
Likes Leo Liu and Delta2
So I guess the acceleration of the system is constant? Somehow I thought the acceleration would be time varying (the system doesn't look that simple, the tension and the spring force should be time varying) that's why I thought we would have to solve differential equation.
Let me answer my own question, the acceleration will be time varying but it only asks for the acceleration when spring is extended by L, not for the full function a(t).
So what would be the solution to this problem? I am curious.
Likes Delta2
I hope I understood it right now
Let ##y## be the downward distance traveled by the configuration from its starting position, let the tension in the string on the left be ##T## (and since the pulley must be frictional in order to satisfy the "no-slip" condition, this tension will be different to that on the right hand side, which is ##k[2y]##). Let the angular speed of the disk about its centre be ##\omega##. When the configuration descends one unit, the spring stretches by two units.We can write down 4 equations:$$\begin{align*}
\text{Energy} &: 0 = \frac{1}{2} (M+m)\dot{y}^2 + \frac{1}{2}I \omega^2 + \frac{1}{2}k(2y)^2 - (M+m)gy \\ \\
\text{Newton II} &: (M+m)g - T - k(2y) = (M+m)\ddot{y} \\ \\
\text{Torques about CM} &: TR - k(2y)R = I\dot{\omega} \\ \\
\text{"No-slip" condition} &: \dot{y} = \omega R \implies \ddot{y} = \dot{\omega} R
\end{align*}$$And also let ##I \equiv Mr^2##, as noted earlier.
Brilliant. I didn't get the equation which relates ##\omega## to ##\dot y##, and ##\Delta x_{spring}=2\Delta y##. Although my intuition tells me the second equation (x=2y) is true, could you prove it algebraically?
Here's a way to think about it...
cut the string at two points at the same height on either side, then move the lower piece of the system down a distance ##y##. To fill the two gaps you made in the string, you insert two more bits of string each of length ##y## into the gaps, one for each gap.
Okay I think I have proved it: ##y=1/2(l-\pi R)\implies |\Delta y|=|y-0|=1/2 [(l'-\pi R)-(l-\pi R)]=1/2(l'-l)=1/2 \Delta x_{spring}##, where l' is length after, I is the length before, y is the distance from the point of attachment to the CM of the wheel.
As regards the angular speed of the wheel, the angle it rotates during a period multiplied by the radius is equal to the increase in the length of the distance from the point of attachment to the point where the string contacts the left side of the pulley (##\theta R=h_1##), and we label this distance as ##h_1##. It is easy to see that ##\dot h_1=\dot y##, so ##\omega R=\dot y##.
My obsession with rigor have blinded me to the big picture.
Likes etotheipi
I think you could simplify that, by saying just that the rate at which the spring extension increases is equal to the rate at which the total length of the cord increases. This must clearly hold, since if ##L = L_0 + \delta##, then ##dL/dt = d\delta/dt##. If the configuration moves down by a distance ##d## in some time interval ##\delta t##, the total length of the cord increased by an amount ##2d##.
Thanks guys for your help, I think I figured it out ..
Related to Find the velocity and acceleration of a pulley in a mass-spring system
1. What is a pulley in a mass-spring system?
A pulley is a simple machine that consists of a wheel with a groove around its circumference, used to change the direction of a force applied to a rope or cable. In a mass-spring system, a pulley is often used to connect a mass to a spring, allowing for the transfer of energy between the two.
2. How do you calculate the velocity of a pulley in a mass-spring system?
The velocity of a pulley in a mass-spring system can be calculated using the equation v = ωr, where v is the velocity, ω is the angular velocity, and r is the radius of the pulley. The angular velocity can be found by dividing the linear velocity of the mass by the radius of the pulley.
3. What is the relationship between the acceleration of a pulley and the mass-spring system?
In a mass-spring system, the acceleration of the pulley is directly related to the acceleration of the mass attached to the spring. This is because the pulley is connected to the mass by the spring, so any acceleration of the mass will also cause the pulley to accelerate.
4. How do you find the acceleration of a pulley in a mass-spring system?
The acceleration of a pulley in a mass-spring system can be found using the equation a = ω²r, where a is the acceleration, ω is the angular velocity, and r is the radius of the pulley. The angular velocity can be found by dividing the linear acceleration of the mass by the radius of the pulley.
5. What factors can affect the velocity and acceleration of a pulley in a mass-spring system?
The velocity and acceleration of a pulley in a mass-spring system can be affected by several factors, including the mass of the object attached to the spring, the stiffness of the spring, and the friction between the pulley and its axle. Additionally, the initial conditions of the system, such as the initial displacement and velocity of the mass, can also impact the velocity and acceleration of the pulley.
