Find the velocity of the 14kg mass just before it hits the ground
In summary, Peter calculated that the 14kg mass will hit the ground with a velocity of 6.5m/s. However, his calculation was incorrect and the actual velocity was 5.2m/s.
PeterPeter
23
A 14kg mass is attached to one side of a vertical pulley and an 8kg to the other.
The 14kg mass is 5m above the ground. The 8kg is just resting on the ground. The pulley is frictionless and weightless.
Find the velocity of the 14kg mass just before it hits the ground.
F=ma;
v^2=u^2+2a*s where s is the distance
Draw a free body diagram for the 14kg mass. Take downwards as positive,
Let g= acceleration due to gravity. The the net force on the 14Kg body is
F=14g-8g Newtons (acting down).
The 14Kg accelerates downwards with acceleration, a, given by:
a=(14g-8g)/14 = 4.2 m/s^2
Thus, since the acceleration is constant:
v^2=0 + 2*a*5
v= 6.5 m/s
This doesn't agree with the answer given is 5.2 m/s^2! So where have I gone wrong?
Your calculation for the acceleration is incorrect. I'd take a step back and spell out exactly how you're deriving your force equation. Remember there is an acceleration constraint. There will be at least two separate equations concerning the net forces on the heavier mass and the lighter mass. You'll need to relate those equations to derive a single equation for the acceleration.
Addendum: there will be three separate equations if you also want to spell out the tension in the rope holding the masses together. Notice the rope's tension will be constant given the wording of the problem.
Oops. Seems I skipped a step! Thanks.
Intuitively
8a=T1-8g
14a=14g-T2
T1=T2
=> (8+14)a= 14g-8g
which gives the correct answer after a bit of algebra.
ONE FURTHER QUESTION
If the down direction is taken as positive, shouldn't these equations be...
(T1 act upwards
8a=-T1+8g
14a=14g-T2
T1=-T2
which gives a= (14g+8g)/(14g+8g) which is wrong.
Where is the error in the signs?
PeterPeter said:
T1=-T2
You're forgetting that the pulley turns the string 180 degrees. The tensions are the same, including the sign, as far as the weights are concerned.
I don't quite understand why you have to worry about tension and all these redundant equations, your original line of reasoning was much more direct, and perfectly correct (except for one small error).
You had everything right except you forgot that it's not only the 14kg side that's accelerating, it's the entire system (so the mass would be (14+8)kg). So instead of dividing the force by 14 to get the acceleration, you should have divided by 22.
This would have given you the correct answer.
PeterPeter figured that out already (see post #3).
But he'd like to understand where his second approach goes wrong.
Obviously one doesn't have to for this particular problem, but doing so helps minimize errors for one; note that OP made his "small error" after skipping a step (as he admitted). Also, some physics professors require that you draw force diagrams, identify all forces (including tension) and write out corresponding equations, and otherwise show all work. Finally, sooner or later he'll run across tougher versions of this problem (in which there is more than one pulley, the pulleys have mass and/or friction, etc.), and keeping accurate track of all forces will become a virtual necessity.
Yes!
Exactly!
Here are my current thoughts.
Taking down as positive:
For 8Kg weight, where a is the acceleration of the 8Kg:
8a=-T1+8g
For 14Kg weight where b is the acceleration of the 14Kg:
14b=14g-T2
For Pulley (since the tension on both sides of the string acts down):
N=T3+T4
Finally, since one weight accelerates up and the other down:
a=-b
I guess (if the rope is massless etc)
T3=-T1
T4=-T2
Is this correct so far?
FAQ: Find the velocity of the 14kg mass just before it hits the ground
1. How do you calculate velocity?
In order to calculate velocity, you need to know the distance an object has traveled and the time it took to travel that distance. The formula for velocity is velocity = distance / time.
2. What is the mass of the object?
The mass of the object is given in the question as 14kg. This is an important factor in calculating velocity because it affects the object's acceleration due to gravity.
3. How does acceleration due to gravity affect the velocity?
Acceleration due to gravity is a constant force that causes objects to accelerate towards the ground at 9.8 meters per second squared. This means that as the object falls towards the ground, its velocity increases at a constant rate.
4. Why is it important to find the velocity just before the object hits the ground?
Knowing the velocity just before the object hits the ground can help us understand the impact and potential damage caused by the object. It can also be useful in predicting the trajectory of the object for future events.
5. Are there any other factors that can affect the velocity of the object?
Yes, there are other factors that can affect the velocity of the object, such as air resistance and the angle at which the object is falling. However, for the given question, these factors are not mentioned and can be assumed to be negligible.
