Find the velocity vector of a curve at point r(t)
In summary, the conversation discusses finding the velocity vector of a particle traveling along a hyperbola with a constant speed of 5 cm/s. The relevant example shows an example of finding the arc length parametrization and the steps involved in the process. The conversation also includes a question about a possible mistake in the sample problem provided by the teacher.
Unart
27
What is the velocity vertor of a particle traveling to the right along the hyperbola y=x-1 which constant 5 cm/s when the particles location is (2, ##\frac{1}{2}##)?
The Length of path forumula.
$$ s\,=\int_a^b ||r'(t)||\,dt $$
Please don't make me write you the magnitude formula, LaTeX is a pain, it's going to take me a while to type out everything.
3. Relevant example
This is an example finding the Arc Length which is need it order to find the unit velocity vector of the Arc Length. There were a few steps I didn't understand well. I'll point them out to you. I have a feeling is probably some Calculus 2 or 1 I'm forgetting.
Find the arc length Parametrization of r(t) = <t2,t3>
assume t>0
r'(t) = <2t,3t2>
||r'(t)|| =(4t2+9t4)1/2 ##\Rightarrow## t (4+9t2)1/2
So now we integrate...
S(t) = ##\int_0^t t(4+9t^2)^{1/2}\,dt## u=t2; du=2t dt ##\Rightarrow\frac{du}{2} = t\,dt##
This is where he completely looses me. How did t become t2? Where does the 1/9 come from, is this like as if he did u=9t2 instead?
S(t) = ##\frac{1}{2}\int_0^{t^2} (4+9u)^{1/2}\,du##
S(t) = ##\frac{1}{2}\cdot\frac{2}{3}(4+9u)\cdot\frac{1}{9}\int_0^{t^2}##
S(t) = ##\frac{1}{27}[(4+9(t)^2)^{3/2}-8]##
Invert
27s = (4+9t2)3/2-8 ##\Rightarrow## 9t^2=(27s+8)2/3-4
t2=(s+ ##\frac{8}{27}##)-##\frac{4}{9}##
Lastly, how did he get these coordinates?
δ(s)= ##\left( (s+\frac{8}{27})^{2/3}-\frac{4}{9},[(s+\frac{8}{27})^{2/3}-\frac{4}{9}]^{3/2}\right)##
4. The attempt at a solution
This problem has little to do with this problem other than I have to do the first step in order to find the velocity vector at said point on the curve when the velocity is a constant 5cm/s.
if X=t then y=t-1 ##\Rightarrow\hspace {30mm} R(t)=<t,t^{-1}>##
R'(t) = <1,-t-2>##\Rightarrow## ||R'(t)||=(1+##\frac{1}{t^4}##)1/2
##\int_0^t (1+\frac{1}{t^4})^{1/2})\Rightarrow u=t^{-4}\, and \,du= -4t^{-5} dt\, or\, \frac{du}{-4t^-5}=dt##
which leads to
##\frac {-4}{t^{5}}\int_0^t (1+u)du##
5. Summary
So, did I do something wrong? Where do I go from here? And, could someone help explain what the teacher did?
Please and thankyou! :-)
What, exactly, is the question here? You ask about the velocity vector but then give as a "relevant example" "finding the arc length". One has nothing to do with the other.
The curve y= 1/x can be written as parametric equations x= s y= 1/s where I have just used "s" as an "alias" for "x". We can write the "position vector" as <t, 1/t>. Differentiating, the tangent vector is <1, -1/t^2>. In particular, the object will be at <2, 1/2> when t= 2 and there the tangent vector is <1, -1/4>. That has length ("magnitude") sqrt(1+ 1/16)= sqrt(17/16)= sqrt(17)/4. Divide the vector <1, -1/4> by that to get the "unit tangent vector" and multiply by 5 cm/s to get a vector tangent to the curve with "magnitude" 5 cm/s- the velocity vector.
Whew! Couldn't see the trees for the forest on that one. I had the right idea before I went to class on Friday, but somehow did some arithmetic or algebra error, and thought about the teacher not going over the chapter. Yesterday he said/ and also read on the book that the derivative of the Parameterization of arc length will give you the unit speed. So I thought you had to do that to get the unit velocity vector along the curve.
I realize what I've done wrong and am moving on.
However I would still like some help understanding the sample problem on the teacher gave us. Please, anyone??
3. Relevant example
assume t>0
r'(t) = <2t,3t2>
Yes, the appropriate substitution would have been ##u = 9t^2,~du=18t\, dt##. Instead he first does ##u=t^2,~du=2tdt## and has to make up for it later with ##u=9t,~du=9 dt##, which he doesn't write out explicitly.
S(t) = ##\frac{1}{2}\cdot\frac{2}{3}(4+9u)\cdot\frac{1}{9}|_0^{t^2}##
Related to Find the velocity vector of a curve at point r(t)
1. What is a velocity vector?
A velocity vector is a mathematical representation of the speed and direction of an object's motion. It is a vector quantity, meaning it has both magnitude (speed) and direction.
2. How is the velocity vector of a curve at a specific point calculated?
The velocity vector of a curve at a point is calculated by taking the derivative of the curve's position function at that point. This derivative represents the rate of change of the curve's position over time, which is equivalent to its velocity.
3. What is the significance of finding the velocity vector of a curve?
The velocity vector of a curve allows us to understand the motion of an object at a specific point on the curve. It can help us determine the object's speed, direction, and acceleration at that point.
4. Can the velocity vector change along a curve?
Yes, the velocity vector can change along a curve. This is because the velocity of an object can change as it moves along a curved path due to changes in speed and direction.
5. How is the velocity vector related to the tangent vector of a curve?
The velocity vector is always tangent to the curve at a given point. This means that the velocity vector and the tangent vector are always parallel to each other and have the same direction. However, the magnitude of the velocity vector may be different from the magnitude of the tangent vector.
