Find the Velocity when accelration is not constant
In summary, a particle moves along the positive x-axis with an acceleration in meters per second squared which increases linearly with x expressed in millimeters, as shown on the graph for an interval of its motion. If the velocity of the particle at x = 40 mm is 0.36 m/s, determine the velocity at x = 130 mm.
Northbysouth
249
Find the Velocity when acceleration is not constant
A particle moves along the positive x-axis with an acceleration in meters per second squared which increases linearly with x expressed in millimeters, as shown on the graph for an interval of its motion. If the velocity of the particle at x = 40 mm is 0.36 m/s, determine the velocity at x = 130 mm.
I have attached an image of the question.
I had thought to use:
vx= v0x+at
or
s = s0 + v0xt +1/2*at2
But due to the acceleration not being constant these equations are not suitable. I'm guessing that I need an integral but I'm not sure how to start. Any help would be appreciated.
Consider the work done by the force that is accelerating the particle.
Well, you have a(x) = bx with b given.
You also have a = dv/dt = dv/dx * dx/dt = v dv/dx
So v dv/dx = bx.
This diff. eq. can easily be solved by separation of variables. Remember the constant of integration which you determine from the given initial condition ...
You surely meant a(x) = bx + c.
I surely did. :redface:
Same approach, though.
I've only recently started learning about differential equations so bear with me.
From what I understand I should get:
v dv/dx = bx + C
v dv = (bx + C)dx
∫v dv = ∫(bx + C)dx
v2/2 = bx2/2 + Cx + D
I then know that v(0.040 meters) = 0.36 m/s and that I can use this information to find D but how do I find b and D? Is b just the gradient of the slope?
Pick any two values of x. Then, since a = bx + c, you should get two linear equations for b and c with known values of a and x. Solve them.
v dv/dx = bx + C
v dv = (bx + C)dx
∫v dv = ∫(bx + C)dx
Yes, voko has shown you how you can get b and c. Remember y = (slope)*x + y-intercept from high school algebra? In this case b is the slope and c is the a-intercept.
You did well with solving the diff. eq. BTW.
I got it. The answer is 1.0366 m/s.
Thank you to everyone for your help.
Just for fun, here's how I would have solved it using the method I hinted at in my earlier post:
ΔKE = ∫F.dx
Δ(v2/2) = ∫a.dx
The integral is the area under the curve, so you can just read it off of your diagram. No need for any formal calculus.
The methods are entirely equivalent, of course. And until you are comfortable with the math, probably best to work things out as you did.
FAQ: Find the Velocity when accelration is not constant
What is the difference between constant and non-constant acceleration?
Constant acceleration refers to a situation where the rate of change of velocity remains the same over time, while non-constant acceleration means that the rate of change of velocity is varying over time.
How do you determine the velocity when acceleration is not constant?
To find the velocity when acceleration is not constant, you can use the equation v = u + at, where v is the final velocity, u is the initial velocity, a is the acceleration, and t is the time interval. Alternatively, you can also use integration to find the velocity from the acceleration function.
What factors affect the velocity when acceleration is not constant?
The velocity when acceleration is not constant is affected by the initial velocity, the acceleration itself, and the time interval. Other factors such as air resistance and friction may also play a role in determining the final velocity.
Can the velocity be negative when acceleration is not constant?
Yes, the velocity can be negative when acceleration is not constant. This indicates that the object is moving in the opposite direction of its initial velocity. For example, if a car is slowing down while moving forward, its velocity will be negative.
How does non-constant acceleration affect the motion of an object?
Non-constant acceleration can cause an object to have a changing velocity and therefore a changing position over time. This means that the object may speed up, slow down, or change direction at different points during its motion.
