Find the velocity when the ball rolls without slipping
In summary, the conversation discusses a homework problem involving a thin spherical shell sliding with an initial velocity on a table until friction causes it to roll without slipping. The question asks for the translational velocity of the shell as a fraction of its initial velocity. The conversation covers the relevant equations and concepts, including the conservation of angular momentum and the importance of considering the signs of the variables. It also highlights the relevance of using concrete examples for better understanding.
vbrasic
73
A thin spherical shell is sliding with velocity ##v_0## on a table initial until friction eventually causes it to roll without slipping. Find its translational velocity when the it rolls without slipping as a fraction of ##v_0##.
$$I=\frac{2}{3}MR^2$$
$$I\dot{\omega}=RF$$
We have for a thin spherical shell that $$\frac{2}{3}MR^2\dot{\omega}=RM\dot{v}.$$ Using this we can get a relation between ##\dot{\omega}## and ##\dot{v}##. We have that, $$\frac{2}{3}R\dot{\omega}=\dot{v}.$$ Integrating both sides with respect to time gives, $$\frac{2}{3}R\omega=v-v_0.$$ When the ball rolls without slipping we have that ##\omega=\frac{v}{R}##. So we have that $$\frac{2}{3}v=v-v_0,$$ such that $$v_0=1/3v\to 3v_0=v.$$ This doesn't make logical sense to me however, as ##v_0## should be the max translational velocity. According to this the ball's velocity is increasing which shouldn't be the case.
Why is this true? Angular momentum is conserved about the point of contact because there is no net torque about that point. Start from there.
This is just like a bowling ball. The ball slides initially and then as friction takes over it rolls. Depending on your release you can even impart a side spin resulting in a curved path with the intent of striking at a point to knock over all ten pins.
How is that relevant to the question?
Your mistake is that you have been inconsistent regarding signs.
In ##\frac{2}{3}MR^2\dot{\omega}=RM\dot{v}##, think about how the positive sense of ω relates to the positive direction of v.
Compare that with their relationship in ##\omega=\frac{v}{R}##.
kuruman said:
Why is this true?
By considering how the frictional force affects linear and angular acceleration.
That is certainly the easiest method in this problem, but there is potential for ambiguity regarding "point of contact" as a reference axis. It should be a point fixed in an inertial frame which happens to be on the locus of the points of contact. This is different from point of contact as a moving (and accelerating) point; that would likely lead to the wrong answer.
Likes Merlin3189
In this particular problem, one could pick as reference the starting point on the flat surface at which the ball has velocity v0 or any other fixed point on the surface. It was not my intention to introduce ambiguity by implying that one may calculate the angular momentum about a moving point of contact which in this case accelerates until the sphere transitions to rolling without slipping. "Fixed point on the surface" is less ambiguous.
Engineering students like to have concrete examples they can visualizw.
This student seems to be pretty much on top of the conceptual aspect, just made a mistake over signs.
Related to Find the velocity when the ball rolls without slipping
1. How is velocity defined when the ball is rolling without slipping?
Velocity is defined as the rate of change of position of the ball over time. In the case of rolling without slipping, the velocity is the linear velocity of the center of the ball.
2. What factors affect the velocity of a ball rolling without slipping?
The velocity of a ball rolling without slipping is affected by the radius of the ball, the surface it is rolling on, and the forces acting on the ball such as friction and gravity. It is also dependent on the initial conditions of the ball, such as its initial velocity and angular velocity.
3. How is the velocity of a ball rolling without slipping calculated?
The velocity of a ball rolling without slipping can be calculated using the formula v = ωr, where v is the linear velocity, ω is the angular velocity, and r is the radius of the ball.
4. Is the velocity different for a ball rolling with and without slipping?
Yes, the velocity of a ball rolling without slipping is different from the velocity of a ball rolling with slipping. This is because when a ball rolls without slipping, there is no relative motion between the point of contact and the surface it is rolling on, whereas in the case of slipping, there is relative motion.
5. How is the velocity of a ball rolling without slipping affected by the surface it is rolling on?
The surface on which the ball is rolling can affect its velocity due to the presence of friction. If the surface is rough, there will be more friction, which can slow down the ball's velocity. On the other hand, if the surface is smooth, there will be less friction, allowing the ball to roll at a higher velocity.
