Find the wave function of a particle bound in a semi-infinite square well
It should be:ψ2 = B2eik2x + C2e-ik2x, k2 = sqrt[2mE]/h_bar, x ≥ aSo that should fix the issue of having to deal with e-ik2(∞).You can simplify that a bit using $$\sin x = \frac{e^{ix}-e^{-ix}}{2i}$$ In fact, if you step back a bit, your first boundary condition tells you A1=-B1 so that you can write ##\psi_1(x) = A \sin k_1x##.Thank you! That makes things much simpler. I just have
BPMead
Consider the semi-infinite square well given by V(x) = -V0 < 0 for 0≤ xa and V(x) = 0 for x > a. There is an infinite barrier at x = 0 (hence the name "semi-infinite"). A particle with mass m is in a bound state in this potential with energy E ≤ 0. Solve the Schrodinger equation to derive ψ(x) for x ≥ 0. Use the appropriate boundary conditions and normalize the wave function so that the final answer does not contain any arbitrary constants.
[-h_bar2/2m]ψ'' + V(x)ψ = Eψ
  • Schrodinger Equation for 0 ≤ xa and x > a:
    [-h_bar2/2m]ψ'' - V0ψ = Eψ, 0 ≤ xa
    [-h_bar2/2m]ψ'' = Eψ, xa
  • Rewrite Schrodinger equations:
    ψ'' + 2m(E+V0)/h_bar2 = 0, 0 ≤ xa
    ψ'' + 2mE/h_bar2 = 0, xa
  • Solve Schrodinger equations:
    ψ1 = A1eik1x + B1e-ik1x, k1 = sqrt[2m(E+V0)]/h_bar, 0 ≤ xa
    ψ2 = A2eik2x + B2e-ik2x, k2 = sqrt[2mE]/h_bar, xa
  • k2 is negative, and the wave function must not blow up at x = ∞, so A2 = 0:
    ψ2 = B2e-ik2x, k2 = sqrt[2mE]/h_bar, xa
  • Apply boundary conditions:
    ψ1(0) = 0
    ψ1(a) = ψ2(a)
    ψ'1(a) = ψ'2(a)
    1st condition: A1 + B1 = 0
    2nd condition: A1eik1a + B1e-ik1a = B2e-ik2a
    3rd condition: ik1A1eik1a - ik1B1e-ik1a = -ik2B2e-ik2a
Now I have 3 equations for 3 unknowns, A1, B1, and B2. But I have been trying to solve this algebraically for quite awhile, and I just can't get it to work. When I solve A1 and B1 in terms of B2 and try to plug them into the third condition, I just get B2 cancelling on both sides. Maybe I'm being really dumb about basic math but I would really appreciate if someone could help with this. Thanks!
Actually, the way you defined k2, it's imaginary because E ≤ 0. It's usually better to define ##k_2 = \sqrt{-2mE}/\hbar##, so you can avoid those error-inducing factors of i.
    ψ1(0) = 0
    ψ1(a) = ψ2(a)
    ψ'1(a) = ψ'2(a)
Once you get it down to everything in terms of one constant, you're finished with this part. To determine the constant, you require the wave function to be normalized.
What conditions did you get on k1 and k2? A non-trivial solution exists for only certain values.
Thank you so much for your response! I can see why you would define k2 that way, I guess I kept it imaginary so that ψ1 and ψ2 would have a similar format. The way I defined them should still theoretically work right? Or do I have to change it?
So I should solve in terms of one constant, but then how do I normalize when there are two wave functions? Do I integrate ψ1 from 0 to a and then add that to the integral of ψ2 from a to ∞, and set that equal to 1?
It'll work out either way.
Yes, that's what you would do.
Okay, when I solve that system of equations, I get:
A1 = B2e-ik2a / (eik1a - e-ik1a)
B1 = -B2e-ik2a / (eik1a - e-ik1a)
Plugging these into normalize:
Let j = e-ik2a / (eik1a - e-ik1a)
jB22∫eik1x - e-ik1xdx + B2∫e-ik2x = 1
Then I get
jB2/ik1 [eik1a-eik2(0)] - jB2/-ik1 [e-ik1(a) - e-ik1(0)] + B2/-ik2 (e-ik2(∞) - e-ik2(0)) = 1
What is e-ik2(∞)? Is that still 0? Even if it is, my answer looks unbelievably ugly.
I just noticed a mistake in your original post. The way you defined k2, it's purely imaginary and equal to
$$k_2 = i\left(\frac{\sqrt{-2mE}}{\hbar}\right)$$ where the quantity in the parentheses real and positive. Consequently, ik2 is purely real and negative. This implies that the A2 term vanishes as x→∞ but the B2 term blows up.
Okay, if we are going to include trig functions anyway, there is a simpler way that I saw to set this up:
ψ1 = A1sin(k1x) + B1cos(k1x)
Since ψ1(0) = 0, B1 = 0
So:
ψ1 = A1sin(k1x)
ψ2 = A2eik2x
Since ψ1(a) = ψ2(a):
A2 = A1sin(k1a) / eik2a
Now normalize to find constants:
∫A1sin(k1x)dx + ∫A2eik2xdx
Solving this, I get C = [1-cos(k1a)-sin(k1a)/eik2a]-1
Which doesn't really look simple enough to be right...
Remember you have to integrate the square of the modulus to normalize the wave function.
Ah! You're right. So what I got was:
A12∫sin2(k1x)dx + A12sin2(k1a)/e2ik2a∫eik2xdx = 1
That works out to:
1 = A12[a/2 - (1/4)sin(2k1a) - sin2(k1a)/(ik2eik2a)]
Is that the right way to get A1?
Right idea. I really suggest you get rid of the unnecessary i's.
FAQ: Find the wave function of a particle bound in a semi-infinite square well
1. What is a semi-infinite square well?
A semi-infinite square well is a theoretical model used in quantum mechanics to describe the energy levels and wave functions of a particle confined to a limited space. It consists of a square potential well with one side extending infinitely, creating a barrier for the particle.
2. How does a particle become bound in a semi-infinite square well?
A particle becomes bound in a semi-infinite square well when its energy is less than the potential energy of the barrier formed by the infinite side of the well. This means that the particle is unable to escape the well and is confined within its boundaries.
3. What is the wave function of a particle bound in a semi-infinite square well?
The wave function of a particle bound in a semi-infinite square well depends on the energy level of the particle. It is a mathematical function that describes the probability of finding the particle at a particular position within the well. It is typically represented by the Greek letter psi (ψ).
4. How is the wave function of a particle bound in a semi-infinite square well calculated?
The wave function of a particle bound in a semi-infinite square well is calculated using the Schrödinger equation, which is a fundamental equation in quantum mechanics that describes the behavior of a particle in a given potential. It involves solving a differential equation to determine the possible energy levels and corresponding wave functions for the particle.
5. What are the applications of the wave function of a particle bound in a semi-infinite square well?
The wave function of a particle bound in a semi-infinite square well has various applications in quantum mechanics, including understanding the behavior of electrons in atoms and molecules, and in the development of new technologies such as quantum computing. It also serves as a fundamental concept in the understanding of quantum mechanics and its applications in other fields of science and technology.
