- #36
Helly123
- 581
- 20
Chestermiller said:For the heat removed in step CA, this is a constant pressure process, so $$Q=\Delta H$$. What is ##\Delta H## for this change?
Gives me 7.5PoVo. Wow, the same as trapezoid area..Chestermiller said:The x1's and the x2's should be switched in your final result. If I factor the correct final result, I get:
$$\int_{x_1}^{x_2}{ydx}=(x_2-x_1)\frac{(mx_2+b)+(mx_1+b)}{2}$$Now, what if $$p=4p_0-\frac{p_0}{V_0}(V-V_0)=5p_o-\frac{p_0}{V_0}V$$so that $$m=-\frac{p_0}{V_0}$$ and $$b=5p_0$$and $$x=V$$ and $$y = p$$ and $$x_1=V_0$$ and $$x_2=4V_0$$What does your equation give?
But, why in trapezoid formula the heigh is 3Vo
Isn't it $$ W = \frac{4Vo + Vo}{2}*3Po$$
The height is 3Po
