Find the work done on a monoatomic gas in this P-V diagram
In summary: In the integral you just wrote, you put the limits of integration...At point A, when P = 1, V = 1while point B, when P = 4, V = 1point C, P = 1, V = 4At point A, when P = 1, V = 1while point B, when P = 4, V = 1point C, P = 1, V = 4At point A, when P = 1, V = 1while point B, when P = 4, V = 1point C, P = 1, V = 4At point A, when P = 1, V = 1while point B, when
  • #36
Chestermiller said:
For the heat removed in step CA, this is a constant pressure process, so $$Q=\Delta H$$. What is ##\Delta H## for this change?
Chestermiller said:
The x1's and the x2's should be switched in your final result. If I factor the correct final result, I get:
$$\int_{x_1}^{x_2}{ydx}=(x_2-x_1)\frac{(mx_2+b)+(mx_1+b)}{2}$$Now, what if $$p=4p_0-\frac{p_0}{V_0}(V-V_0)=5p_o-\frac{p_0}{V_0}V$$so that $$m=-\frac{p_0}{V_0}$$ and $$b=5p_0$$and $$x=V$$ and $$y = p$$ and $$x_1=V_0$$ and $$x_2=4V_0$$What does your equation give?
Gives me 7.5PoVo. Wow, the same as trapezoid area..
But, why in trapezoid formula the heigh is 3Vo
Isn't it $$ W = \frac{4Vo + Vo}{2}*3Po$$
The height is 3Po
  • #37
$$\Delta H=n\frac{5}{2}R(T_A-T_C)$$
If i just sum W + ##\Delta##U
Is it ok?
  • #38
The height is 3Po
No way. The two parallel sides are vertical, and the altitude is horizontal.
  • #39
Is it ok?
Sure, provided you include the correct work for that step.
Likes Helly123
  • #40
