Find time at which position vector points towards origin
In summary, the author finds that two definite values for t can be found for the i and j components of the position vector when the velocity is pointing towards the origin.
Taniaz
364
The position vector of a particle at time t is R=(1-t^2)i+(3t-5t^2)j. Find the time at which P is moving (a) towards the origin (b) away from the origin.[/B]
I've thought about this for a while but I've come to the conclusion that I'm not really sure what they're asking for when they say towards and away from the origin. I know that the acceleration is constant because if you keep deriving you get a = -2i - 10j
[/B]
They are asking for a time when the velocity ##R'## is such that given ##R = x \hat i + y \hat j ##, ##R' ## is pointing in the direction of the origin.
For example, if R = (x,y), what would a velocity vector pointing toward the origin look like?
How did you deduce that? The velocity vector would be tangent to R?
The velocity vector is the time derivative of the position vector by definition. Similarly, acceleration is the derivative of velocity.
Yes I do know that but I'm not sure what it looks like pointing towards and away from the origin.
In general, when we discuss vectors, they only have magnitude and direction. They do not have a specific anchor point. (Forces do have a point of application as well as being vectors.) But in this question, you need to think of the velocity as being a vector from the current position.
The position vector R starts from the origin so supposing it lies at some point (x,y) at time t, pointing away from the origin, so will we draw it from the tip of this position vector? If it's towards the origin, will it be pointing downwards from the tip?
Yes, except that I'm not sure what you mean by 'downwards' there. It will be pointing from current position towards origin.
If it is pointing from the current position to the origin, then it will just be coinciding with the position vector in the opposite direction?
Yes.
But how does this tell us about time? We find the derivative of x to get velocity and equate it to negative of the position vector?
Yes, but only the direction, not the magnitude
But that doesn't make sense because if you equate v= -R, how do you solve for t?
You know the position at time t and the velocity at time t.
Do we have to find an expression or a definite value for t?
Two definite values.
We do get 2 values for t for both the i and j components because it's a quadratic equation but for the one with towards the origin, the solutions aren't whole numbers I think
Please post your working.
v=-R and v=(-2t)i + (3-10t)j
(-2t)i + (3-10t)j = -(1-t^2)i - (3t-5t^2)j
(-2t)i + (3-10t)j = (-1+t^2)+(-3t+5t^2)j
(-2t)i = (-1+t^2)i and (3-10t)j=(-3t+5t^2)j
t = -1-sqrt2 or t = sqrt 2-1 for the i components and
t= (-7- sqrt 109)/10 or t =sqrt 109-7/10
As I posted, the vectors are not equal and opposite. They only have opposite directions. The magnitudes can be different.
How did 'and' become 'or'?
Sorry I meant and. Is this correct though?
You are looking for one t that satisfies both the i and j components at the same time.
Let v = cR, where c is any non-zero constant. If c is negative then the velocity is pointing toward the origin. When c is positive, the velocity is pointing away from the origin.
Ah that makes sense! Thank you Haruspex and RUber! :smile:
After adding in the c, you should be able to find a solution that satisfies your and condition.
##t = ( -1 - \sqrt{2} \text{ or } -1 + \sqrt{2} ) \text{ and } ( \frac{-7 - \sqrt{109}}{10} \text{ or } \frac{-7 + \sqrt{109}}{10} )## are inconsistent.
## -2t \hat i + (3-10t) \hat j = (c-ct^2 )\hat i - (3ct + 5ct^2)\hat j \\
ct^2 -2t -c = 0 \text{ and } 5ct^2 + (3c-10)t + 3 = 0##
Correct me if I've misunderstood what you just said. So up till the values of t, it's correct? We just need to find which values of t give c as negative and that will indicate that it's pointing to the origin?
The work you posted in #19 is correct for v = (-1)R. Replace -1 with a c, and rewrite the equations.
I understand but then how do you solve for c?
ct^2−2t−c=0 and 5ct^2+(3c−10)t+3=0
I put in the values for t that I found and then see if c is negative?
Ok so the values of t all seem to give c=-1 which seems to be alright in this case. I'm guessing this equations are general ct^2−2t−c=0 and 5ct^2+(3c−10)t+3=0 where you can substitute for whatever you think c is and solve for t?
I don't see how c = -1 works.
You have two times for i and two different times for j.
You need a time that satisfies both i and j.
The two equations in #24 must both be true. One method is to solve for t in terms of c using linear algebra, then solve one or both of the equations for t as a quadratic.
Finally set your solutions for t equal to each other to find c. You should be able to find a positive and a negative c.
I understand what you're saying but isn't this a little too complicated for a 1 mark A'Level question?
  • #31
##\vec v = c \vec R## means that vx=c Rx and vy =c Ry. Dividing the first equation with the second one, vx/vy=Rx/Ry . Substitute the expressions in terms of t,
[tex]\frac{1-t^2}{3t-5t^2}=\frac{-2t}{3-10t}[/tex]
and solve for t. You get two solutions. One of them means a positive c , the other solution means a negative one.
  • #32
Thank you RUber, Haruspex and ehild for your help! Much appreciated! :)
  • #33
If you are familiar with cross products, another route is to note that the collinearity of the position and velocity vectors means their cross product is zero. This avoids bringing in c and gives you an equation in t only (though it might be nasty). Having extracted the possible values of t, you could then evaluate the two vectors at those times to find out which has velocity towards the origin and which away.
  • #34
So I got that t= 1/3 and t = 3
At t=3, c = 3/4 and at t=1/3, c = -3/4
So at t=1/3 it's pointing towards the origin.
  • #35
Looks right.
Related to Find time at which position vector points towards origin
1. How do I find the time at which a position vector points towards the origin?
To find the time at which a position vector points towards the origin, you first need to have the position vector and its corresponding time values. Then, you can use the dot product formula to calculate the angle between the position vector and the origin vector. This angle will be zero when the position vector is pointing towards the origin. Finally, you can use this angle and the angular velocity of the position vector to calculate the time at which the position vector points towards the origin.
2. What is a position vector?
A position vector is a mathematical representation of the position of a point in space. It is a directed line segment that starts from the origin and ends at the point in question. It is typically denoted by a lowercase letter with an arrow on top, such as r.
3. What is the dot product formula?
The dot product formula is a mathematical formula used to calculate the angle between two vectors. It is given by a · b = |a||b|cosθ, where a and b are two vectors, |a| and |b| are their magnitudes, and θ is the angle between them.
4. How is the angular velocity of a position vector calculated?
The angular velocity of a position vector is calculated by taking the derivative of the position vector with respect to time. It is denoted by the symbol ω (omega) and is measured in radians per unit time.
5. Can the time at which a position vector points towards the origin be negative?
Yes, the time at which a position vector points towards the origin can be negative. This can happen if the position vector is moving in the opposite direction of the origin vector and then changes direction to point towards the origin. In this case, the angle between the two vectors will be greater than 180 degrees, resulting in a negative time value.
