Find triangles with areas that are integers
In summary: Yes, other regular polygons can have integer areas as well. Take the polygon with vertices (x, y), (x+1, y+1), (x+2, y+2), (x+3, y+3), (x+4, y+4), (x+5, y+5), (x+6, y+6), (x+7, y+7), (x+8, y+8), (x+9, y+9), (x+10, y+10), (x+11, y+11), (x+12, y+12), (x+13,
Mikestone
TL;DR Summary
Can one find which triangles (other than right-angled ones) have areas wheich are integers?
It is pretty obvious that all right-angled triangles whose sides are integers will have areas which are also integers. Since either the base or height will be an even number, half base x height will always come out exactly.
However, I have only found one non-right-angled triangle where this is the case. If the sides are 13, 14 and 15 then (if I've done it right) this gives an area of 84.
Are there any other such triangles with exact integer areas as well as sides, and if so is there any rule for finding them?
Likes Janosh89
Mathematics news on Phys.org
Can't we have a right triangle with two sides that are both of length 1? How are you defining "right-angled" triangle?
Edit: I see what you're asking. Some use the convention that a right triangle has 2 "sides" and a "hypotenuse".
Mikestone said:
Summary:: Can one find which triangles (other than right-angled ones) have areas wheich are integers?
Sure. You can choose two side lengths as any numbers you wish.
It is obvious that this is not the case. Height and base can be the two perpendicular legs, hence the area is a half integer.
Why not choose ##g=h=1##?
Why do you want to know? Which other regular triangles have you tried?
Heron's formula may be helpful to you. A triangle of side lengths a, b, and c has area given by the following equation:
$$Area = \sqrt{s(s-a)(s-b)(s-c)},$$
Where s is the semiperimeter of the triangle. Restrict areas to positive integers, and see what falls out in combination with other conditions (such as the triangle inequality).
Likes Janosh89, berkeman and fresh_42
Take any right triangle with integer sides and join it with its mirror image along one of its sides to form an isosceles triangle. Area is obviously double that of the right triangle.
Whoops, my mistake. I should probably have said "Pythagorean" rather than "right-angled'. On the other hand, if a right triangle had sides 1 and 1 its hypotenuse would of course *not* be an integer.
... which you never explicitly required! We all had to guess what you meant.
  • Sad
Likes pbuk
How about 5 5 6
It surprises me that there are many. Actually I was surprised there were any.
Apart from 1-2-3, 2-3-5, 3-4-7, 2-13-15, etc. which are a bit trivial, they seem to be at least as common as Pythagorean triples.
4-13-15, 9-10-17, 11-13-20, 7-15-20, 10-17-21, 13-20-21, 12-17-25, 3-25-26, ... , 26-35-51, (34 so far)
Likes Janosh89 and phyzguy
arydberg said:
How about 5 5 6
This is an example of @mathman's post #5, starting with a 3-4-5 right triangle.
I think that's a bit unfair, the meaning was clear (to me at least, and also to @Stephen Tashi on second reading) from the context.
These are called Heronian triangles, entry A072294 in the On-Line Encyclopedia of Integer Sequences is a good start for further enquiry.
Likes jim mcnamara, Janosh89, mfb and 3 others
The Wikipedia entry also has a lot of information.
Thanks. I do know that formula, and indeed it was while toying with it that I happened upon the 13,14,15 triangle. I tried various other combinations but was evidently unlucky in my choices as they all produced irrational numbers. As I was already familiar with a set of formulae to produce Pythagorean Triples, I wondered if there was anysuch way of deriving non-Pythagorean ones.
Thanks a lot. The Wiki entry seems to give me what I was looking for.
Also thanks to everyone else who has tried to help. In my schooldays I was good at maths, but there's clearly still a lot of terminology with which I am unfamiliar.
Which was what I have said: implicit, not explicit.
Actually there are an infinite number, which can be easily generated. Take any two different integers ##m## and ##n##, let ##a=2mn##, ##b=n^2-m^2## and ##c=n^2+m^2##. To get primitives, ##m## and ##n## should be relatively prime and one of them should be even, while the other is odd.
Likes Merlin3189 and phyzguy
Aren't those specifically the formulae for generating *Pythagorean* triangles (ie right-angled ones) rather than heronian ones in general?
Yes.
https://en.wikipedia.org/wiki/Heronian_triangle
has formula to get all Heronian triangles
mathman said:
Yes.
Thanks.
I did find the formulae, though you rather need to "read the fine print", as the results which they produce often have to be divided by their highest common factor in order to get the triangle in its "primitive" form.
For a really comprehensive investigation of this and related topics you could start with this relatively recent paper and follow the references back.
FAQ: Find triangles with areas that are integers
How do you find triangles with areas that are integers?
To find triangles with areas that are integers, you can use the formula A = 1/2 * base * height. Plug in different values for the base and height that will result in a whole number for the area. For example, a base of 4 and a height of 4 will result in an area of 8, which is an integer.
What is the smallest possible integer area for a triangle?
The smallest possible integer area for a triangle is 1. This can be achieved with a base and height of 2, or any other combination that results in a product of 2 when multiplied and then divided by 2.
Can a triangle have an area of 0?
No, a triangle cannot have an area of 0. In order for a triangle to exist, it must have a base and height that are both greater than 0. Therefore, the minimum possible area for a triangle is 1.
Is it possible for a triangle to have a negative area?
No, it is not possible for a triangle to have a negative area. The formula for finding the area of a triangle only involves multiplication and division, which will always result in a positive number. Additionally, the concept of area represents a physical quantity and cannot be negative.
How can you determine if a triangle has an integer area without calculating it?
You can determine if a triangle has an integer area by looking at its dimensions. If the base and height are both integers, then the area will also be an integer. Additionally, if the triangle has sides with integer lengths and forms a right angle, the area will also be an integer according to the formula A = 1/2 * base * height.
