MHB Find Triplets to Satisfy $x+y+z+xy+yz+zx=xyz+1$
  • Thread starter Thread starter anemone
The discussion centers around finding all triplets of positive integers (x, y, z) that satisfy the equation x+y+z+xy+yz+zx=xyz+1, with the condition x ≤ y ≤ z. It is established that if x is greater than or equal to 4, no solutions exist due to the inequality derived from the equation. For x equal to 2, the solutions (y, z) are found to be (3, 13) and (5, 8), while for x equal to 3, the only solution is (3, 7). The confirmed solutions are (2, 3, 13), (2, 5, 8), and (3, 3, 7). The discussion concludes with acknowledgment of contributions from participants.
anemone
MHB
POTW Director
Determine all triplets $(x,\;y,\:z)$ of positive integers such that $x \le y \le z$ and
$x+y+z+xy+yz+zx=xyz+1$.
Mathematics news on Phys.org
Hello.
(x+1)(y+1)(z+1)=2(1+xyz)
At a glance:
(1,0,0) \ (0,1,0) \ (0,0,1) \ (-1,-1,-1)
Only meets the two restrictions: (1,0,0)
Regards.
The above solution is not correct. The question asks for positive integers, and $0$ IS NOT POSITIVE!
$$2,4,13$$
$$2,5,8$$
$$3,3,7$$
mente oscura said:
Hello.
At a glance:
Regards.
Thanks for participating, mente oscura! But your answer isn't correct. I'm sorry.:(
$$2,4,13$$
$$2,5,8$$
$$3,3,7$$
Yes, those three are the only solutions but if you don't mind me asking, I would like to see how you approached the problem, sounds good to you?
[sp]If $x$ (the smallest of these numbers) is $\geqslant4$ then each of $x,y,z$ is $\leqslant\frac14yz$; and each of $xy,xz,yz$ is $\leqslant yz$. Therefore $x+y+z+xy+yz+zx \leqslant \frac{15}4yz$. But $xyz + 1>4yz > \frac{15}4yz$. So there cannot be any soluions with $x\geqslant4.$
If $x=2$ then the equation becomes $2yz+1 = yz + 3(y+z) + 2$, so that $yz - 3(y+z) = 1$, or $(y-3)(z-3) = 10$. The only positive integer solutions with $y\leqslant z$ are $(y-3,z-3) = (1,10)$ or $(2,5)$, giving $(y,z) = (3,13)$ or $(5,8).$
If $x=3$ then the equation becomes $3yz+1 = yz + 4(y+z) + 3$, so that $yz - 2(y+z) = 1$, or $(y-2)(z-2) = 5$. The only solution is $(y-2,z-2) = (1,5)$, giving $(y,z) = (3,7)$.
Thus the only solutions are those given by eddybob:$(x,y,z) = (2,3,13),\ (2,5,8),\ (3,3,7)$.[/sp]
Thank you Opalg for participating and also your well explained solution!
Solution provided by other:
Let $x-1=p$, $y-1=q$ and $z-1=r$, the equation may be written in the form $pqr=2(p+q+r)+4$, where $p,q,r$ are integers such that $r \ge q \ge p \ge 0$. Observe that $p=0$ is not possible, for then $0=2(p+q)+4$ which is impossible in non-negative integers. Thus we may write this in the form
$2 \left( \dfrac{1}{pq}+\dfrac{1}{qr}+\dfrac{1}{rp} \right) +\dfrac{4}{pqr}=1$.
If $p \ge 3$, then $q \ge 3$ and $r \ge 3$. Then left side is bounded by $\dfrac{6}{9}+\dfrac{4}{27}$ which is less than 1.
We conclude that $p=1$ or $p=2$.
Case I:
Suppose $p=1$. Then we have $qr=2(q+r)+6$ or $(q-2)(r-2)=10$. This gives $q-2=1, r-2=10$ or $q-2=2$ and $r-2=4$ (recall $r \ge q$). This implies $(p,q,r)=(1,3,12), (1,4,7)$
Case II:
If $p=2$, the equation reduces to $2qr=2(2+q+r)+4$ or $qr=q+r+4$. This reduces to $(q-1)(r-1)=5$. Hence $q-1=1$ and $r-1=5$ is the only solution. This yields $(p,q,r)=(2,2,6)$
Reverting back to $x, y, z$ we get three triplets $(x,y,z)=(2,4,13),(2,5,8),(3,3,7)$.
Here is a little puzzle from the book 100 Geometric Games by Pierre Berloquin. The side of a small square is one meter long and the side of a larger square one and a half meters long. One vertex of the large square is at the center of the small square. The side of the large square cuts two sides of the small square into one- third parts and two-thirds parts. What is the area where the squares overlap?
