Find truth value of propositions
  • MHB
  • Thread starter evinda
  • Tags
    Value
In summary: This can be shown by using the Modus Ponens.In summary, the proposition $p \to q$ is false if and only if $peq q$
evinda
MHB
3,836
Hello! (Wave)
We suppose that the propositions $p,q$ are propositions such that the proposition $p \to q$ is false.
Find the truth values for each of the following propositions:
  1. $\sim q \to p$
  2. $p \land q$
  3. $q \to p$
I have thought the following:
Since the proposition $p \to q$ is false, either $p$ is true and $q$ is false, either $q$ is true and $p$ is false.
Thus, we have the following truth table:
$\begin{matrix}
p & q & \sim q & \sim q \to p & p \land q & q \to p\\
0 & 1 & 0 & 1 & 0 & 0\\
1 & 0 & 1 & 1 & 0& 0
\end{matrix}.$
So, $\sim q \to p$ is at each case $1$ since $\sim q$ and $p$ have the same values.
As for $p \land q$ it is always $0$ since $p$ and $q$ have different values.
$q \to p$ is for the same reason $0$.
Is everything right? Or am I somewhere wrong? 🤔
I would note immediately that "∼q→p" is equivalent to "p→q" so it is false.
I fact, of the four combinations of "true" and "false" for p and q the only case in which
p→q is false is p true and q false. In that case p∧q is false but q→p is true.
Hey evinda!
As HallsofIvy already pointed out, I'm afraid this is not correct. (Worried)
I haven't understood why $p \to q$ is only false when p is true and q is false. Isn't it also false when p is false and q is true? 🤔 🤔
Why is in this case $q \to p$ true? :oops:
Klaas van Aarsen said:
Hey evinda!
I haven't understood why "∼q→p" is equivalent to "p→q" .. (Sadface)
The implication $p\to q$ is false iff p is true and q is false. 🤔
However, it is not equivalent to $\lnot q\to p$ being false.
Instead it is equivalent to $\lnot q\to\lnot p$ being false. 🤔
Could you explain to me why this happens? :unsure::unsure::unsure:
In general it holds that $p \to q \iff \lnot q \to \lnot q$, right? (Thinking)
The implication $p\to q$ means that if $p$ is true that $q$ must also be true.
It follows that the implication must be false if $p$ is true but $q$ is false, doesn't it? 🤔
That leaves the other 2 cases where $p$ is false.
They have been defined such that $p\to q$ is true if $p$ is false.
That's all there is to it. :geek:
evinda said:
In general it holds that $p \to q \iff \lnot q \to \lnot p$, right?
Yep. (Nod)
So if we have a proposition , say, $x \to y$, it is considered that $x$ is true, right?
And so if the proposition is false, given that $x$ is true, it must hold that $y$ is false, right? 🤔
The case that $p$ is false doesn't need to be checked, since we assume that $p$ is true, right? Or have I understood it wrong? (Thinking)
Yep. (Nod)
Generally we also need to check cases where $p$ is false.
However, for this particular problem we must have that $p$ is true and $q$ is false, since otherwise $p\to q$ wouldn't be false. 🤔
Yep. (Nod)
How can this be shown that $p \to q \iff \lnot q \to \lnot p$ ? (Thinking)
So, in this case we have that $p \to q$ is false. That means that $p$ is true and since the proposition is false we get that $q$ is false.
We want to find the truth value of $\lnot p \to q$.
$p \to q$ is false iff $\lnot p \to q$ is true,since $ \lnot p$ is false and so is $q$. Is this right and sufficient? (Thinking)
One way to show it, is to consider that the left hand side is false if and only if $p=\text{true}$ and $q=\text{false}$.
If we have indeed that $p=\text{true}$ and $q=\text{false}$, then $\lnot q=\text{true}$ and $\lnot p=\text{false}$, isn't it?
So $\lnot q \to \lnot p$ is false if and only if $p=\text{true}$ and $q=\text{false}$. 🤔
Alternatively we can make a truth table for both expressions and see that those truth tables are identical. 🤔
This is not relevant for the problem at hand though is it? (Wondering)
Ok... (Nerd)
Is the explanation I wrote above sufficient for the specific problem? 🤔
You have distinguished the cases $p=1,q=0$ and $p=0,q=1$.
But that second case cannot occur since $0\to 1$ is true.
So we should only look at the first case: $p=1, q=0$. 🤔
It means in particular that:
$$(q\to p) = (0\to 1) = 1$$
which is not what you had. (Worried)
We have the following truth table:
\begin{equation*}
\begin{array}{c|c|c|c|c}
p & q & p\to q & \lnot q & \lnot q \to p & p\land q & q \to p\\
\hline
1 & 1 & 1 & 0 & 1 & 1& 1\\
1 & 0 & 0 & 1 & 1& 0& 1\\
0 & 0 & 1 & 1 & 0& 0& 1\\
0 & 1 & 1 & 0 & 1& 0&0
\end{array}
\end{equation*}
Since $p \to q$ is false, we are interested in the case when $p=1$ and $q=0$. Thus $\lnot q \to p$ is true, $p \land q$ is false and $q \to p$ is true. Right?
So we didn't need to complete the whole truth table sincechecking the truth values of $p \to q$ at the beginning, we see that it can hold just for $p=1$ and $q=0$, right? :unsure:
Yep. (Nod)
Yep. (Nod)
Nice, thank you! :cool:
FAQ: Find truth value of propositions
What is a proposition?
A proposition is a statement or claim that can be either true or false.
How do you determine the truth value of a proposition?
The truth value of a proposition is determined by whether the statement is supported by evidence and logical reasoning. It can also be determined by testing the statement against real-world observations or experiments.
Can a proposition have a truth value of both true and false?
No, a proposition can only have one truth value. It cannot be both true and false at the same time.
What is the difference between a simple and compound proposition?
A simple proposition is a statement that cannot be broken down into smaller statements, while a compound proposition is made up of two or more simple propositions connected by logical operators such as "and", "or", or "not".
How does the truth value of a compound proposition relate to the truth values of its simple propositions?
The truth value of a compound proposition is determined by the truth values of its simple propositions and the logical operators connecting them. For example, if both simple propositions are true and connected by "and", the compound proposition will also be true.
