Find Two Numbers -- Have Two Equations and Two Unknowns
You say?Yes, your setup and solution are correct. Good job!In summary, the two numbers that add up to 72 are 48 and 24, with one number being twice the other.
nycmathguy
Find Two Missing Numbers
System of Equations
Two numbers add up to 72. One number is twice the other. Find the numbers.
Let x and y be our two numbers.
Two numbers add to 72.
x + y = 72
I can use x or y for this next set up.
x = 2y
Here is the system:
x + y = 72
x = 2y
You say?
Likes Delta2
nycmathguy said:
You say?
I say solve it and get on with your life.
EDIT: if you don't know it already, the way to check this is not to ask on an internet forum but rather to just SOLVE it and then plug the numbers back into the problem and see if they fit
+1
I don't understand @phinds, why he shouldn't post this here and ask if he is doing any mistakes? That's what we usually do in the homework forums.
Sure, but first he should do what I suggested and then he would know that he didn't NEED to post here. Isn't that what you would have done?
I guess he wanted a confirmation from us that he formed the right system of equations. And also he might need help on how to solve it.
Yeah, but this post from one of his other threads is a bit worrisome, IMO:
nycmathguy said:
I will post hundreds of word problems here in the coming months.
If most of those are simple ones that he can solve and check for himself, that's not a good use of PF. We're here for when you try your best but get stuck, or when you plug your solutions back into the original word problem they don't work...
nycmathguy said:
Here is the system:
x + y = 72
x = 2y
You say?
I'm with @phinds here. @nycmathguy has done the heavy lifting of coming up with a system of equations, which is more than 50% of the problem. IMO he should have solved this simple system and checked his solution against the problem statement. If the solution worked in the problem statement, no need to even post the question. If the solution didn't work, then that would have been reason for starting a thread, and we could have helped out.
Likes phinds and berkeman
So, everything I do here is wrong, huh?
No, that's not what I'm saying. What I am saying is why didn't you take a stab at solving the system of equations you came up with?
It's a serious waste of your time and energy to get snippy about appropriate criticism rather than trying to learn from it. You did a great job of creating the right equations and has been said, that's half (actually I think it's a lot MORE than half) of the battle in solving word problems.
Now you just need to learn to follow through, solve your equations, and check your work. Until you learn to do that you will continue to feel lost w/ word problems.
Likes Tom.G, symbolipoint and berkeman
Understood. However, did you ever stop to think that perhaps I work a 40-hour overnight shift and sleeping during the day is crucial? Yes, I have the weekend off but weekend hours fly by. My dad is to say that the weekend is an illusion.
You post a system of equations,. and then "you say?".
It's really not clear what you mean here?
- Do you mean to ask if this system is correct. (yes)
- Do you really want to say that you have a system, but no idea how to solve it? (you'll probably get some hint about what to do if you ask that)
We won't solve it, if you really need the answer, you can type it in wolfram alpha, or an online graphical calculator.
I understand you made some related posts about word problems, but you really shouldn't count on anyone having read those. People don't know how to react to a post like this.
I simply wanted to know if my set up is correct. Naturally, I know how to solve this system of equations.
Likes Delta2
Here is the system:
x + y = 72
x = 2y
You said to solve it and move on.
Let x + y = 72 be Equation A.
Let x = 2y be Equation B.
Replace x in A by 2y and solve for y.
x + y = 72
2y + y = 72
3y = 72
y = 72/3
y = 24
I now plug y = 24 into either A or B to find x.
I will use Equation B.
x = 2y
x = 2(24)
x = 48
The two missing numbers are 24 and 48.
Evidence:
24 + 48 = 72
72 = 72
Are you happy now? I can't seem to do anything right here, huh? My Homework Statement is wrong. My Relevant Equations is always wrong. What the heck!
I need to follow through, huh
Ok.
Here is the system again:
x + y = 72
x = 2y
x + y = 72
2y + y = 72
3y = 72
y = 72/3
y = 24
x = 2y
x = 2(24)
x = 48
Evidence:
24 + 48 = 72
72 = 72
Extension:
I needed to set up a system of equations to find the two missing numbers. Can this be done without setting up a system of equations? Say I came across this problem on a test without knowing anything about a system of equations or how to set it up, what would I need to do to find the missing numbers?
You do need a system of equations, however, once you get used to working on these very simple problems you can often just do them quickly in your head without needing to write anything down.
Likes nycmathguy
You said "simple problems" in your reply. You do understand that my threads will increasingly get harder as I go through the textbooks, right? This also applies to word problems as well. Of course, this particular problem can be solved by middle school students. My goal is to learn precalculus through calculus 3. Obviously, the questions are going to get harder. Along the way, I will find time to occasionally post algebra, geometry, trigonometry and calculus word problems. I am slowly going through the books. Rushing leads to more confusion.
nycmathguy said:
You said "simple problems" in your reply. You do understand that my threads will increasingly get harder ...
Of course, and as they do the ability to solve them in your head will quickly vanish. I was specific about my comment relating to the simple ones, like the one being discussed.
Likes nycmathguy
I get it now.
Here's a different way to think about things. At an elementary level, it's common to undertake dozens of problems that are all essentially the same. In this case, one number is some multiple of another and they sum to a given total. You repeat the process for dozens of questions and get the idea.
"Real" maths, however, is more about seeing the general pattern and encoding it mathematically. For example:
One number is ##a## times another number and they sum to ##b##. What are the numbers?
If we take the two numbers to be ##x## and ##y## we have:
##y = ax##
##x + y = b##
This gives:
##x = \frac {b}{1 + a}##
##y = \frac{ab}{1 + a}##
That, IMHO, is mathematics.
To check things out for your example: ##a = 2, b = 72##:
##x = \frac{72}{3} = 24##
##y = \frac{2 \times 72}{3} = 48##
Likes symbolipoint, nycmathguy and Delta2
You just did a generalization of the problem and its solution, why do you think that the generalization is mathematics while the solution for the specified instance of problem is not mathematics?
To master any subject you need the enlightenment - the insights that allow you really to understand what you are doing.
With chess, for example, it's the difference between learning the moves and being able to play the game. With computer programming it's the difference between learning the syntax and being able to put a significant programme together. And, IMO, with mathematics it's the difference between plodding through the same algebraic steps time after time and seeing the underlying algebra.
Likes symbolipoint
I can't disagree with this but usually to understand the insights (which are generalized insights if i can call them that way, they refer to a generic version of the problem) we have to work through specific instances, examples of the problem , usually one (at least a novice-newcomer) doesn't understand the generalized version unless he works with specific examples first.
##y = ax##
##x + y = b##
This gives:
Impressive reply. Great math notes for me.
Likes PeroK
PeroK said:
This gives:
The only problem I see with this, is having the student memorize the "formulas" without knowing how to derive them. Then in the quiz, it is "what formula do I use" rather than "how do I solve the system."
  • Skeptical
Likes PeroK and nycmathguy
I hated that back in my student days. Here's a formula: now memorize it. What does the formula mean? Students have zero idea.
Likes symbolipoint
My concern is more with a certain type of student, who chooses to ignore (not understand) the derivation, instead choosing to memorize the formulas. There are plenty of homework help threads here that begin "what formula do I use to..."
Your comment astonishes me and perhaps shows the depth of the problem for those who do not think mathematically. You're not supposed to memorise any formulas! You're supposed to recognise that there is a general algebraic method behind all the problems that are essentially the same, but with different numbers. You're supposed to see the algebraic pattern and begin to digest the real purpose of algebra.
The counterargument, which I think this thread shows is valid, is that the longer you soldier on one problem at a time, seeing no connection between one problem and the next, the harder it is ever to escape that cycle. Your brain never makes the underlying connections because you're not looking for them. And by the time someone sits you down and says "now for some real algebra", your brain has been trained not to think like that and it's a shock to the system.
Likes symbolipoint
I think I have been misunderstood, probably because I was not clear on the nature of my concern.
Likes berkeman
  • #31
Regardless of newcomer, almost-newcomer, or whatmore, students will often enough find the SAME exercise but as different examples, using differing values and maybe too diverse situations --but all of the examples being the SAME general form. That is why studying and applying algebra that way is so useful.
FAQ: Find Two Numbers -- Have Two Equations and Two Unknowns
What is the concept of "Find Two Numbers -- Have Two Equations and Two Unknowns"?
The concept of "Find Two Numbers -- Have Two Equations and Two Unknowns" is a mathematical problem-solving technique where two equations with two unknown variables are used to find the values of those variables.
How do you solve a "Find Two Numbers -- Have Two Equations and Two Unknowns" problem?
To solve a "Find Two Numbers -- Have Two Equations and Two Unknowns" problem, you need to set up two equations with two unknown variables, such as x and y. Then, you can use algebraic methods, such as substitution or elimination, to solve for the values of x and y.
What are the common types of "Find Two Numbers -- Have Two Equations and Two Unknowns" problems?
The common types of "Find Two Numbers -- Have Two Equations and Two Unknowns" problems include age problems, distance problems, and mixture problems. These types of problems involve using two equations to find the values of two unknown quantities, such as the ages of two people or the distance between two objects.
What are the key steps to solving a "Find Two Numbers -- Have Two Equations and Two Unknowns" problem?
The key steps to solving a "Find Two Numbers -- Have Two Equations and Two Unknowns" problem are: 1) Identify the two unknown variables and set up two equations with those variables. 2) Use algebraic methods, such as substitution or elimination, to solve for the values of the unknown variables. 3) Check your solution by plugging in the values of the variables into the original equations.
How can "Find Two Numbers -- Have Two Equations and Two Unknowns" problems be applied in real life?
"Find Two Numbers -- Have Two Equations and Two Unknowns" problems can be applied in real life situations, such as calculating the ages of family members or finding the distance between two cities. These types of problems also have applications in science and engineering, where unknown variables need to be determined in order to solve complex equations and models.
