Find u,v of the differential equation
  • MHB
  • Thread starter evinda
In summary, the exercise involves finding u and v, the solutions to the differential equations y''-3y'-4y=0 and y''+4y'-5y=0 respectively. The two solutions intersect at the point (0,0) and have the same deviation. However, the limit given in the exercise, \lim_{x\rightarrow \infty}\frac{v^{4}(x)}{u(x)}=\frac{5}{6}, cannot be reached with these conditions. Thus, it is not possible to find u and v with this given information.
evinda
MHB
3,836
If the graph of the solution u of the differential equation [tex]y''-4y'+29y=0[/tex] intersects the graph of the solution v of the differential equation [tex]y''+4y'+13y=0[/tex] at the point (0,0),find u,v so that:
[tex] \lim_{x\rightarrow \infty}\frac{v^{4}(x)}{u(x)}=\frac{5}{6} [/tex]
How can I do this??
Re: Find u,v!
How can I do this??
Hi evinda! (Smirk)
Did you try and solve those DE's with the given boundary condition?
Btw, can it be that the limit should let $x \to 0$ instead of $x \to \infty$?
Re: Find u,v!
Have you found the solutions to both differential equations? :)
Re: Find u,v!
I found that the solution of the differential equation [tex]y''-4y'+29y=0[/tex] is [tex] y(x)=c_{1}e^{2x}sin(5x)+c_{2}e^{2x}cos(5x) [/tex] and that the solution of the differential equation [tex] y''+4y'+13y=0[/tex] is [tex] y(x)=d_{1}e^{-2x}sin(3x)+d_{2}e^{-2x}cos(3x) [/tex] .
At the exercise I am looking at,it says that [tex] x\rightarrow \infty [/tex],but if you think that it might be wrong,it could be a misprint :confused:
I tried to find the limit but I don't know what to do to find u and v :confused:
Re: Find u,v!
I think that u is not equal to [tex] y(x)=c_{1}e^{2x}sin(5x)+c_{2}e^{2x}cos(5x) [/tex] and v not to [tex] y(x)=d_{1}e^{-2x}sin(3x)+d_{2}e^{-2x}cos(3x) [/tex] .Because if it was like that,we wouldn't use the limit that is given from the exercise..Or am I wrong??But,how else could I find u and v?
Re: Find u,v!
Good! (Smile)
To find u and v you have to use the boundary condition (0,0).
That is, u(0)=0 and v(0)=0.
After that you can determine the limit.
Re: Find u,v!
I like Serena said:
Good! (Smile)
I used it and found that [tex] u(x)=c_{1}e^{2x}sin(5x) [/tex] and [tex] v(x)=d_{1}e^{-2x}sin(3x) [/tex] .And now?how can I continue?
Re: Find u,v!
evinda said:
I used it and found that [tex] u(x)=c_{1}e^{2x}sin(5x) [/tex] and [tex] v(x)=d_{1}e^{-2x}sin(3x) [/tex].
Very good. :cool:
Substitute in \(\displaystyle \lim_{x\rightarrow \infty}\frac{v^{4}(x)}{u(x)}\)?
Re: Find u,v!
I like Serena said:
Very good. :cool:
It is equal to [tex] \lim_{x\rightarrow \infty}\frac{d_{1}^{4}e^{(-2x)^{4}}sin^{4}(3x)}{c_{1}e^{2x}sin(5x)} [/tex] ,right?But can this limit[tex] \rightarrow \frac{5}{6} [/tex] ?:confused:
Re: Find u,v!
Correct!
Neh. It can't.
Re: Find u,v!
I like Serena said:
Correct!
Neh. It can't.
The exercise asks me to find u,v so that:
So,is the right answer that we can't find u,v with this condition?
Re: Find u,v!
Yep. That's what I think.
Re: Find u,v!
Ok...Thank you :)
Re: Find u,v!
I am looking again at the exercise and realized that I didn't write right the differential equations. :eek: $u$ is the solution of the differential equation $y''-3y'-4y=0$,and $v$ the solution of this: $y''+4y'-5y=0$,u and v intersect at the point (0,0) ,where they have also the same deviation.Could you tell me,if the limit exists now? :eek:
Re: Find u,v!
You solved it before... can you solve it again? (Thinking)
Re: Find u,v!
I found that the solution of the differential equation $y''-3y'-4y=0$ is $u(x)=c_{1}e^{4x}+c_{2}e^{-x}$ and that of this differential equation $y''+4y'-5y=0$ it is $v(x)=d_{1}e^{x}+d_{2}e^{-5x}$.
Then from these conditions : $u(0)=v(0) \text { and } u'(0)=v'(0) $ I found that $c_{1}=\frac{2d_{1}-4d_{2}}{5} \text{ and } c_{2}=\frac{3d_{1}+9d_{2}}{5}$ .Is this right??:confused: But how can I find $u,v$ so that $ \lim_{x\to\infty}\frac{v^{4}(x)}{u(x)}=\frac{5}{6}$ ?
Re: Find u,v!
Substitute?
You may limit yourself to the 2 highest powers of $e^x$ in $v^4(x)$.
Re: Find u,v!
I like Serena said:
Substitute?
The limit is now $\lim_{x \to \infty} \frac{(d_{1}e^{x}+d_{2}e^{-5x})^{4}}{(\frac{2d_{1}-4d_{2}}{5})e^{4x}+(\frac{3d_{1}+9d_{2}}{5})e^{-x}}$,right?
So,you mean that it is equal to thi one:$\lim_{x \to \infty} \frac{d_{1}^{4}e^{4x}}{\frac{2d_{1}-4d_{2}}{5}e^{4x}}=\frac{d_{1}^{4}}{\frac{2d_{1}-4d_{2}}{5}}
Re: Find u,v!
evinda said:
The limit is now $\displaystyle \lim_{x \to \infty} \frac{(d_{1}e^{x}+d_{2}e^{-5x})^{4}}{(\frac{2d_{1}-4d_{2}}{5})e^{4x}+(\frac{3d_{1}+9d_{2}}{5})e^{-x}}$,right?
So,you mean that it is equal to thi one:$\displaystyle \lim_{x \to \infty} \frac{d_{1}^{4}e^{4x}}{\frac{2d_{1}-4d_{2}}{5}e^{4x}}=\frac{d_{1}^{4}}{\frac{2d_{1}-4d_{2}}{5}}
That looks about right. :)
Re: Find u,v!
But...why do we take the two highest powers?? Don't we take the highest powers,only when we have a fraction with polynomials?? Or am I wrong?? (Thinking)
Re: Find u,v!
The same principle applies. The other powers go to zero so fast that they have no impact on the limit.
Actually, it suffices to only look at the highest power.
Divide both numerator and denominator by this highest power and the reason should become clear.
Re: Find u,v!
I understand.. :) I found that $-2d_{2}=3d_{1}^{4}-d_{1}$ .Is this right?So,I can't find a unique solution for $d_{1},d_{2},c_{1},c_{2}$,or is it possible?
Re: Find u,v!
So let's start with 1 solution.
Suppose we pick $d_1=0$, does the corresponding solution for u and v satisfy all conditions?
What if $d_1=1$?
Re: Find u,v!
What if $d_1=1$?
If we have $d_{1}=0$,then $d_{2}=0$,so the denominator will also be equal to $0$ ,something that is not allowed! For $d_{1}=1$ we find that $d_{2}=-1$,and then the limit will be equal to $\frac{5}{6}$..So,can we take any number for $d_{1}$, apart from $0$ ?
Re: Find u,v!
Well... you should also check that the differential equations and the boundary conditions are satisfied...
I like Serena said:
Oh, and:
(Worried) (Bandit) (Evilgrin)
(Giggle)(Bigsmile)(Wasntme)
Re: Find u,v!
From the boundary conditions don't we get that $c_{1}=\frac{2d_{1}-4d_{2}}{5} \text{ and } c_{2}=\frac{3d_{1}+9d_{2}}{5}$ ? (Thinking) And how can I check if the differential equations are satisfied?Aren't they satisfied for any $d_{1},d_{2},c_{1},c_{2}$ ?
Re: Find u,v!
How can I do this??
For $d_1 = 1$, we get $d_2=-1$, and therefore $c_1 = 6/5$ and $c_2 = -6/5$.
So the solutions are:
$$u(x)=\frac 6 5 e^{4x} - \frac 6 5 e^{-x}$$
$$v(x)=e^{x}-e^{-5x}$$
Substituting in $u''-3u'-4u=0$ gives:
$$\left(\frac 6 5 4^2 - 3 \frac 6 5 4 - 4 \frac 6 5\right)e^{4x} - \left(\frac 6 5 + 3\frac 6 5 - 4 \frac 6 5\right)e^{-x} = 0$$
Yay! We verified that this u(x) is actually a solution!
We have confirmation that there is no calculation mistake and that are no weird conditions either.
Then $v(x)$ will probably also be a solution of $v''+4v'-5v=0$.
Furthermore, $u(0) = 0$, which is the same as $v(0)=0$. Also good.
And $u'(0)=\frac 6 5 \cdot 4 + \frac 6 5 = 6$, while $v'(0) = 1 + 5 = 6$.
Yay! More confirmation.So yes, we've got a solution for any $d_1$ with the condition that $2d_1 - 4d_2 \ne 0$ where $−2d_2=3d_1^4−d_1$. Solving that leads indeed to $d_1 \ne 0$.
Yay! It's all good!
Good that you didn't make any calculation mistakes! (Cool)
Re: Find u,v!
Yay! It's all good!
Nice!Thank you very much! :)
FAQ: Find u,v of the differential equation
What is the purpose of finding u and v in a differential equation?
The purpose of finding u and v in a differential equation is to simplify the equation and make it easier to solve. By substituting u and v for the original variables, the equation can be rewritten in terms of these new variables, which may lead to a more straightforward solution.
How do you determine which variable to use for u and v?
The choice of u and v is not always straightforward and may require some trial and error. In general, u and v should be chosen to eliminate the highest order derivative in the equation. This means that u and v should be related to the original variables in a way that cancels out the highest order derivative when substituted into the equation.
Can u and v be any function of the original variables?
No, u and v must be chosen carefully to satisfy certain conditions. For example, they should be differentiable functions and should not introduce any new solutions to the equation. It is also important to check that the substitution of u and v does not lead to any contradictions or inconsistencies in the original equation.
Is there a specific method for finding u and v?
There is no one method for finding u and v, as it depends on the specific equation and the creativity of the solver. Some common techniques include using trigonometric or exponential functions for u and v, or using the method of undetermined coefficients to determine the form of u and v.
Can u and v be used for any type of differential equation?
Not all differential equations can be solved using the method of finding u and v. This technique is most commonly used for linear differential equations, where the highest order derivative is multiplied by a function of the other variables. It may also be used for some nonlinear equations, but it is not always effective in these cases.
