guyvsdcsniper
- 264
- 37
- Homework Statement
- Find the universal gravitational constant
- Relevant Equations
- F=Gm1m2/r
I am using pasco's gravitational torsion balance https://www.pasco.com/products/lab-apparatus/fundamental-constants/ap-8215 to find the universal gravitational constant in a lab report.
Two large tungsten masses are positioned close to two smaller masses, causing the torsion balance to oscillate. The balance has a mirror attached to it. A laser is shined on the mirror and reflected on a background. The laser will move with the oscillation of the balance as it oscillates to its equilibrium position. It moves as a damped harmonic oscillator.
I recorded the oscillation of the laser using a timelapse video on my 4th gen iPad pro. Googling, I found the timelapse has a frame rate capture of 1 frame every 4 seconds for videos over 40 minutes (i recorded for 45 minutes). This speed relative to time is 120x.
The problem is that while the data taken from these videos is very useful for tracking the equilibrium position of the laser, the time is a lot more compressed. So my data shows the total oscillation recording in about 25 seconds.
The only thing I can use from this data is find the centerline of the oscillation so I can get an approximate equilibrium point position since the time is so off. The time being off is bad because I need to calculate the period of the oscillations as G is inversely proportional to $T^2$.
My solution is just use a video I recorded in real time with out timelapse to get the period since I have no idea how to fix the time problem. I think fixing the time will also separate my data points by a lot graphically. I just worry about using a chart where in my lab report where only one axis is truly meaningful.
I know I can just explain the time problem in my error analysis but I am just wondering if anyone knows of a way to fix this? How can I convert my compressed timelapse time back to real time?
