Find V(t) of train car with changing mass.
In summary, the conversation discusses a problem involving an empty freight car being pushed with a constant force while coal is being added to the car at a steady rate. The goal is to calculate the velocity of the car as a function of time. Different approaches were suggested, such as using Newton's second law and the concept of momentum. It was also mentioned that when dealing with variable mass problems, it is important to consider the velocity of the added mass and its impact on momentum.
oddjobmj
306
An empty freight car of mass M starts moving from rest with a constant applied force F0. At the same time, coal runs into the car at steady rate b from a hopper above the car at rest along the track. Calculate the velocity of the car as a function of time.
Data: M = 1900 kg; F0 = 47000 N; b = 190 kg/s; t = 6.8 s.
F=m*a
V(t)=v0+a*t
M(t)=M+bt
F=ma=M[itex]\frac{dv}{dt}[/itex]
F dt=M dv
dv=[itex]\frac{F}{M}[/itex]dt=[itex]\frac{F}{M=bt}[/itex]dt
Integrating both sides I get:
v=[itex]\frac{F*ln((bt/M)+1)}{b}[/itex]
Plugging in my known values I find that v(6.8)=128.33 m/s which is incorrect. Any suggestions?
Thank you!
Newtons 2nd law says Ftot=dp/dt= dmv/dt=(dm/dt)*v+(dv/dt)m
Likes 1 person
Thank you, lep11. I'm actually not sure how to solve that. I am very rusty with regard to differential equations.
Can I multiply through by dt to get Ftotaldt=vdm+mdv ?
Then I can integrate both sides to get Ft=2mv where m=M+bt
Ft=2v(M+bt)
v=[itex]\frac{Ft}{2(M+bt)}[/itex]
I tried this and came up with 50.06 m/s which is also not correct.
Hi oddjobmj...Could you please tell what is the correct answer ?
Likes 1 person
I don't have the correct answer, unfortunately. It is an online based program where I have a certain number of attempts.
You have to be careful with that formulation. E.g. how would you represent the case where the coal is falling from a hopper which is itself moving?
Oddjobmj, the problem with your formulation is that it treats the added coal as already having the same forward velocity as the cart. Instead, just think about the total momentum provided by the force in time t and the total momentum obtained by cart plus its load of coal at that time.
Likes 2 people
oddjobmj...You should approach the variable mass system problems using momentum approach.
P(t) = M(t)v(t)
P(t+dt) = ( M(t)+dm )( v(t)+dv )
dP = M(t)dv+v(t)dm
or,dP/dt = M(t)dv/dt+v(t)dm/dt
Now dP/dt =F , dm/dt = b and M(t)=M+bt
F = M(t)dv/dt+bv(t)
F-bv(t) = M(t)dv/dt
dt/M(t) = dv/(F-bv(t))
Integrate with proper limits and you should end up with v=Ft/(M+bt) .
Does that mean we can apply dP/dt approach directly in variable mass problems only when the velocity of the outgoing/incoming mass(added coal) is same as that of the system(car+coal at time t) ?
Likes 1 person
Yes, but it's much easier than that. No calculus is needed. Just think about the total momentum that has been gained by the cart and the coal in it at time t.
Think about what the v dm/dt term means. It says some amount of mass has been added / created at speed v. Since in reality mass does not get created out of nothing, it must have already existed with some momentum. Taking the gain in momentum to be v dm/dt assumes it had no prior momentum (within the reference frame). In the present problem that works because we are taking the added coal to be initially at rest, but it does not work in general.
Likes 2 people
In theory, this approach is always valid. In practice, total momentum ## p(t) = m(t)v(t) ## only in special cases, in general ## p(t) ## is the sum (or integral) of various masses moving at various speeds. For example, if sand is ejected at relative velocity ##v_e##, then ## p(t) = \int_0^t (-m'(\tau)) (v(\tau) + v_e(\tau)) d\tau + m(t) v(t) ## and ## p'(t) = - m'(t) (v(t) + v_e(t)) + m'(t) v(t) + m(t) v'(t) = m(t) v'(t) - m'(t) v_e(t) ##.
Likes 2 people
I know what you have been hinting at :) .This is an excellent way of thinking in the context of the problem.Let oddjobmj figure it out.
Okay…So vdm/dt is the change in the momentum of the added/ejected mass ‘dm’ in inertial reference frame. For this reason ,in rocket equation we have (v-u)dm/dt instead of vdm/dt .
Suppose the cart and hopper both would have been moving at same velocity ‘v’.In that case the term representing change in momentum of the increased mass dm, vdm/dt would have been zero.
Is my understanding correct ?
Likes 1 person
Yes. In the context of the OP, but in a reference frame where the coal in the hopper has a constant nonzero velocity u and mass is transferred to the cart at rate b, you could reason that the change in the momentum for hopper+coal is u dm/dt + m du/dt = -ub. Combining that with vb+m(t)dv/dt for the cart+coal we have F = (v-u)b+m(t)dv/dt.
Likes 1 person
Sorry, I was away for a few days!
P(t) = M(t)v(t)
dP = M(t)dv+v(t)dm
F = M(t)dv/dt+bv(t)
F-bv(t) = M(t)dv/dt
This worked, thank you! I was pretty darn close.
But as I mentioned, there is a much easier way. The cart and all the coal in it started at rest. If it is now mass M+bt and moving with velocity v how much momentum has it gained in total? How much momentum has the force F supplied in time t?
Related to Find V(t) of train car with changing mass.
1. What is the equation for finding the velocity of a train car with changing mass?
The equation for finding the velocity of a train car with changing mass is v(t) = (1/m)(∫F(t)dt) + C, where v(t) is the velocity at time t, m is the mass of the train car, F(t) is the net force acting on the train car at time t, and C is the constant of integration.
2. How does the changing mass of the train car affect its velocity?
The changing mass of the train car affects its velocity because it affects the net force acting on the train car. As the mass increases, the net force decreases, resulting in a decrease in velocity. Conversely, as the mass decreases, the net force increases, resulting in an increase in velocity.
3. What is the significance of the constant of integration in the equation?
The constant of integration, C, represents the initial velocity of the train car at time t=0. It takes into account any initial velocity the train car may have before the net force begins to act on it.
4. How do you determine the net force acting on the train car at a specific time?
To determine the net force acting on the train car at a specific time, you must consider all the individual forces acting on the train car, including gravity, friction, and any applied forces. The net force is then the sum of all these forces.
5. Can this equation be used to find the velocity of any object with changing mass?
Yes, this equation can be used to find the velocity of any object with changing mass, as long as the net force acting on the object is known or can be determined.
