Find velocity of boat as function of the time
In summary, the problem involves a motorboat with mass m moving at velocity Vi on a lake. When the engine is shut down at t=0, the resistance of water is proportional to the boat's velocity, given by f= -rv. Using ΣFx = max and ΣFy = may, the equation for acceleration can be derived as dv/dt = (-mg - rv)/m. However, the force of gravity, mg, may not need to be considered as it is in 90° angle with rv and is in equilibrium with buoyancy.
ays
a motorboat of mass m moves along a lake with velocity Vi. at the moment t=0 the engine of the boat is shut down, assuming the resistance of water to be proportional to the velocity of the boat f= -rv , find the velocity of the boat as a function of time
ƩF = ma
a = dv/dt
ƩF = ma
- mg - rv = ma
am not sure if i am going the right way or not
Hello.
Force and acceleration are vector quantities. You should work with components:
ΣFx = max
ΣFy = may
I think that you should not consider mg as it is in 90° angle with rv
Likes jbriggs444
And it is in equilibrium with buoyancy.
Likes Niladri Dan
Related to Find velocity of boat as function of the time
1. What is the formula for finding the velocity of a boat as a function of time?
The formula for finding the velocity of a boat as a function of time is v(t) = d(t)/t, where v(t) is the velocity, d(t) is the distance traveled, and t is the time elapsed.
2. How do you determine the distance traveled by a boat as a function of time?
The distance traveled by a boat can be determined by multiplying the velocity by the time elapsed. Therefore, the formula for distance as a function of time is d(t) = v(t)*t.
3. Can the velocity of a boat change over time?
Yes, the velocity of a boat can change over time due to factors such as wind, currents, and changes in direction. This is why it is important to calculate velocity as a function of time rather than just a single value.
4. How do you plot the velocity of a boat over time?
To plot the velocity of a boat over time, you would first need to collect data on the distance traveled at different time intervals. Then, using the formula v(t) = d(t)/t, you can calculate the velocity for each time interval and plot it on a graph with time on the x-axis and velocity on the y-axis.
5. Can the velocity of a boat be negative?
Yes, the velocity of a boat can be negative if it is moving in the opposite direction of its initial motion. For example, if a boat starts moving east at a velocity of 10 m/s and then changes course to move west at a velocity of 5 m/s, its velocity would be negative (-5 m/s) in relation to its initial motion.
