MHB Find Velocity of Recoiling Railcar with Conservation of Momentum
  • Thread starter Thread starter Dustinsfl
    Frictionless
The discussion focuses on using conservation of momentum to determine the velocity of a recoiling railroad flatcar when two hobos jump off simultaneously. The derived formula for the car's velocity is v = (2m_h / (m_fc + 2m_h))u, where m_h is the mass of each hobo and m_fc is the mass of the flatcar. The momentum equation is set up as m_fc v = 2m_h (u - v), leading to the final solution after rearranging terms. The original question is confirmed to be from the book "Classical Mechanics" by John Taylor. The thread concludes with the problem being marked as solved.
Dustinsfl
Two hobos, each of mass $m_{\text{h}}$, are standing at one end of a stationary railroad flatcar with frictionless wheels and mass $m_{\text{fc}}$.
Either hobo can run to the other end of the flatcar and jump off with the same speed $u$ (relative to the car).
Use conservation of momentum to find the speed of the recoiling car if the two men run and jump off simultaneously.
Let $v$ be the velocity of the recoiling car.
Then
\begin{alignat*}{3}
m_{\text{fc}}v & = & 2m_{\text{h}}(u - v)\\
v & = & \frac{2m_{\text{h}}}{m_{\text{fc}}}(u - v)
\end{alignat*}
The solution is $v = \frac{2m_{\text{h}}}{2m_{\text{h}}+m_{\text{fc}}}u$.
How did they get that?
Mathematics news on Phys.org
Well, expanding the product gets us
$$m_{fc} v = 2m_h (u-v) = 2m_h u - 2m_h v,$$
and from that
$$m_{fc} v + 2m_h v = (m_{fc} + 2m_h) v = 2m_h u.$$
Finally,
$$v = \frac{2m_h}{m_{fc} + 2m_h} u.$$
If you don't mind me asking, is this question from the book Classical Mechanics by John Taylor? :D
Cheers.
It is from that book but I figured out what they did before you posted; hence, the post was marked solved before then.
Here is a little puzzle from the book 100 Geometric Games by Pierre Berloquin. The side of a small square is one meter long and the side of a larger square one and a half meters long. One vertex of the large square is at the center of the small square. The side of the large square cuts two sides of the small square into one- third parts and two-thirds parts. What is the area where the squares overlap?
  • · Replies 17 ·
