bremenfallturm
- 45
- 11
- Homework Statement
- A particle starts from rest in the point ##A## to the point ##B## along four different paths according to the figure (see my post):
1. A conservative force ##F_{K1}## does work ##10J## on the particle
2. A conservative force ##F_{K2}## does work ##5## on the particle
3. A nonconservative force ##F_{IK}## does work ##-5J## on the particle.
Now assume all forces act at the same time on the particle, when it is moved along the path 4. Find the work done by ##F_{IK}## given that the particle stops at point ##B##
- Relevant Equations
- ##U=\int_{\mathcal C} \vec F \cdot \vec dr##
##U=V(A)-V(B)## if a force is conservative and ##V## is a potential function for it
##U=\oint_{\gamma} \vec F \cdot \vec dr## for a closed curve ##\gamma##
The figure provided with the question is:
I set up the following equation for path 4
##U_{path 4}=U_{Fk1, path 4}+U_{Fk2, path 4}+U_{FIK, path 4}## where ##U_{FIK,AB}## is the unknown.
I know that the work will be the same regardless the path for conservative forces, so I have:
##U_{path 4}=10+5+U_{FIK, path 4} (J)##
The answer key says ##U_{FIK, path 4}=-15J## (no further solution given), but I do not understand why ##U_{path 4}## is ##0##, if I set up my equations correctly and interpret the answer key. I know that mechanical energy is conserved with conservative forces, and that the work done over a closed curve with conservative forces is 0.
How can I come to a reasoning that ##-15J## is correct?
Thanks!
Thanks!
