Find Work of a Force Acted on Mass over Frictionless Surface
In summary, the given force of F(x)=5x^3 (in \frac {N}{m^3}) exerts a work of 2,000 J on a 1-kg mass moving from x = 2m to x = 6m on a frictionless surface. The final speed of the mass is 60 m/s. However, the answer may differ depending on the number of significant digits used.
mrsteve
A force given by [tex]F(x)=5x^3 (in \frac {N}{m^3})[/tex] acts on a 1-kg mass moving on a frictionless surface. The mass moves from x = 2m to x = 6m.
a) How much work is done by the force?
[tex]W=\int F_x from x_o to x_f [/tex]
[tex]\int 5x^3 from x=2 to x=6 = 1.6*10^3[/tex]
Is this correct?
Looks correct to me, mrsteve.
Also, if the speed of the mass is 2 m/s @ x=2 what is the speed at x=6?
[tex]KE=\frac{mv^2}{2}[/tex]
[tex]1600=\frac{(1)(v^2)}{2} => v=5.6*10^1 = 60 m/s[/tex]
Would that be correct?
The book has 2,000 J. I suppose that's because there's only 1 significant digit in mass = 1kg?
[tex]1.6 *10^3 => 2 *10^3[/tex]
Yes, your solution is correct. The work done by a force is given by the integral of the force over the displacement, which in this case is from x=2 to x=6. Since the force is given by F(x)=5x^3, the integral becomes \int 5x^3 from x=2 to x=6, which equals 1.6*10^3. This means that the force has done 1.6*10^3 Joules of work on the mass.
Related to Find Work of a Force Acted on Mass over Frictionless Surface
1. What is the definition of "work" in this context?
Work is a measure of the energy transferred to an object by a force acting on it over a certain distance. In this context, it refers to the energy transferred to a mass by a force acting on it over a frictionless surface.
2. How is the work of a force calculated on a mass over a frictionless surface?
The work of a force on a mass over a frictionless surface is calculated by multiplying the magnitude of the force by the distance the mass moves in the direction of the force.
3. What does a frictionless surface mean in this scenario?
A frictionless surface is a theoretical surface where there is no resistance or friction present. This means that there is no force acting against the motion of the mass, allowing it to move without any energy being lost to friction.
4. How is the direction of the force related to the work done on the mass?
The direction of the force is important in determining the work done on the mass. If the force acts in the same direction as the displacement of the mass, positive work is done. If the force acts in the opposite direction of the displacement, negative work is done.
5. What are some real-world examples of a mass being acted on by a force over a frictionless surface?
A common example is a hockey puck sliding on an ice rink, where the ice provides a nearly frictionless surface for the puck to glide on. Another example is a roller coaster moving along its track, where the wheels and track are designed to minimize friction for a smoother ride.
10K
