MHB Find x and y if x, y are members of real numbers and: (x+i)(3-iy)=1+13i
To solve for x and y in the equation (x+i)(3-iy)=1+13i, the initial expansion leads to two equations: 3x + y = 1 and -xy + 3 = 13. From the first equation, y can be expressed as y = 1 - 3x. Substituting this into the second equation results in a quadratic equation, which factors to (3x + 5)(x - 2) = 0. The solutions yield the pairs (x, y) = (-5/3, 6) and (2, -5), confirming the calculations.
Gladier
I first expanded it to give: 3x-yix+3i+y=1+13i
Then I equaled 3x+y=1 and -yx+3=13
But afterwards I do other steps and get the wrong answer.
Mathematics news on Phys.org
Your approach and posted work are ok.
To continue,
$$3x+y=1\implies y=1-3x$$
$$3-xy=13\implies xy=-10$$
$$x(1-3x)=-10$$
$$(3x+5)(x-2)=0$$
$$(x,y)=\left(-\frac53,6\right),(2,-5)$$
Does that match your results?
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Thread 'Video on imaginary numbers and some queries'
Hi, I was watching the following video. I found some points confusing. Could you please help me to understand the gaps? Thanks, in advance! Question 1: Around 4:22, the video says the following. So for those mathematicians, negative numbers didn't exist. You could subtract, that is find the difference between two positive quantities, but you couldn't have a negative answer or negative coefficients. Mathematicians were so averse to negative numbers that there was no single quadratic...
Thread 'Unit Circle Double Angle Derivations'
Here I made a terrible mistake of assuming this to be an equilateral triangle and set 2sinx=1 => x=pi/6. Although this did derive the double angle formulas it also led into a terrible mess trying to find all the combinations of sides. I must have been tired and just assumed 6x=180 and 2sinx=1. By that time, I was so mindset that I nearly scolded a person for even saying 90-x. I wonder if this is a case of biased observation that seeks to dis credit me like Jesus of Nazareth since in reality...
