MHB Find $x$ for $\sum_{k=1}^{x}\lfloor{\sqrt[4]{k}}\rfloor=2x$
  • Thread starter Thread starter anemone
The discussion focuses on finding integer values of \( x \) that satisfy the equation \( \sum_{k=1}^{x}\lfloor{\sqrt[4]{k}}\rfloor=2x \). The sequence \( a_k \) is defined based on ranges of \( k \), where \( a_k = 1 \) for \( 1 \leq k \leq 15 \), \( a_k = 2 \) for \( 16 \leq k \leq 80 \), and \( a_k = 3 \) for \( 81 \leq k \leq 255 \). Calculations show that \( S_{15} = 15 \) and \( S_{80} = 145 \), leading to the conclusion that for \( n > 80 \), \( S_n \) increases by 3 for each increment in \( n \). The only solution found is \( n = 95 \), which satisfies the equation.
anemone
MHB
POTW Director
Find all integers $x$ such that $\left\lfloor{\sqrt[4]{1}}\right\rfloor+\left\lfloor{\sqrt[4]{2}}\right\rfloor+\left\lfloor{\sqrt[4]{3}}\right\rfloor+\cdots+\left\lfloor{\sqrt[4]{x}}\right\rfloor=2x$.
Mathematics news on Phys.org
[sp]Writing the sequence...
$\displaystyle S_{n} = \sum_{k=1}^{n} a_{k}\ (1)$
... where...
$\displaystyle a_{k} = 1\ \text {if}\ 1 \le k \le 15,\ = 2\ \text{if}\ 16 \le k \le 80,\ = 3\ \text{if}\ 81 \le k \le 255, ...$
... we have to search the value of n for which $\displaystyle S_{n}= 2\ n$. It is easy to see that $\displaystyle S_{15} = 15$ and $\displaystyle S_{80}= 15 + 2\ 65 = 145$. For n> 80 $\displaystyle S_{n}$ increases by 3 at each step so that the value of n for which is $\displaystyle S_{n}= 2\ n$ will be 80 + 160 - 145 = 95. Clearly that is the only solution to the problem...[/sp]
Kind regards
$\chi$ $\sigma$
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Thread 'Video on imaginary numbers and some queries'
Hi, I was watching the following video. I found some points confusing. Could you please help me to understand the gaps? Thanks, in advance! Question 1: Around 4:22, the video says the following. So for those mathematicians, negative numbers didn't exist. You could subtract, that is find the difference between two positive quantities, but you couldn't have a negative answer or negative coefficients. Mathematicians were so averse to negative numbers that there was no single quadratic...
Thread 'Unit Circle Double Angle Derivations'
Here I made a terrible mistake of assuming this to be an equilateral triangle and set 2sinx=1 => x=pi/6. Although this did derive the double angle formulas it also led into a terrible mess trying to find all the combinations of sides. I must have been tired and just assumed 6x=180 and 2sinx=1. By that time, I was so mindset that I nearly scolded a person for even saying 90-x. I wonder if this is a case of biased observation that seeks to dis credit me like Jesus of Nazareth since in reality...
