Find x in [0,2π] to Solve Inequality
In summary, to solve an inequality involving x in the range of [0,2π], you need to isolate the variable x on one side and use basic algebraic operations while considering the given range. The range [0,2π] limits the possible solutions and is important to consider when solving the inequality. The same method can be used for any inequality in this range, but adjustments may be necessary. If the given range is different, the method will also differ. Other factors to consider when solving an inequality in this range include the direction of the inequality and any restrictions on x.
anemone
MHB
POTW Director
3,883
115
Find all \(\displaystyle x\) in the interval \(\displaystyle [0, 2\pi] \) which satisfies \(\displaystyle 2\cos(x) \le \left|\sqrt{1+\sin (2x)}-\sqrt{1-\sin (2x)} \right|\le \sqrt{2}\)
Mathematics news on Phys.org
anemone said:
Find all \(\displaystyle x\) in the interval \(\displaystyle [0, 2\pi] \) which satisfy \(\displaystyle 2\cos x \le |\sqrt{1+\sin (2x)}-\sqrt{1-\sin (2x)}|\le \sqrt{2}\)
If correct, the problem is set up as 'non challenge question' because the requirement is reduced to... $\displaystyle \cos x \le \frac{1}{\sqrt{2}}\ (1)$ ... and the (1) is satisfied for $\displaystyle \frac{\pi}{4} \le x \le \frac{7}{4} \pi$... Kind regards $\chi$ $\sigma$
one solution cos x <= 0
so x is between pi/2 and - 3pi/2
second case cos x > = 0 and sin x >= 0
now sin x < cos x gives
cos x < 1/2 | cos x + sin x - ( cos x - sin x) <= 1/ sqrt(2)
or cos x < sin x <= 1/sqrt(2)
cos x >= 1/sqrt(2) => sin x >= 1/ sqrt(2) so no solution
cos x > 0 and sin x >= cos x gives cos x <= sqrt(2)
siimiliarly ranges sin x < 0 2 ranges | sin x | < cos x and | sin x | > cos x need to be anlaysed
by symetry we get cos <= 1/ sqrt(2)so solution set cos^1 (1/ 2sqrt(2) to 2pi - cos^1 (1/2sqrt(2))
or between pi/4 and 7pi/4edited the solution as there was a mistake and it is corrected
Squaring the expression in the middle gives:
\begin{aligned}\left|\sqrt{1+\sin (2x)}-\sqrt{1-\sin (2x)} \right|^2
&= (1+\sin (2x))+(1-\sin (2x)) - 2 \sqrt{(1+\sin (2x))(1-\sin (2x))} \\
&= 2 - 2 \sqrt{1-\sin^2(2x)} \\
&= 2 - 2 \sqrt{\cos^2(2x)} \\
&= 2 - 2 |\cos(2x)| \\
&= 2 - 2 |2\cos^2 x - 1|
\end{aligned}
If $\cos(2x)> 0$, this reduces to $4 - 4 \cos^2 x$.
If $\cos(2x)\le 0$, this reduces to $4 \cos^2 x$.
The latter case is a 1-1 match for the squared left hand side.
Checking out the cases where $\cos x > 0$ respectively $\cos x \le 0$ yields that the first inequality is always true.
chisigma already gave the solution when looking at the remaining inequalities.
To solve this inequality, we first need to simplify the expression on the right side of the inequality. By squaring both sides and expanding, we get:
1+2\sin(2x) - 2\sqrt{1-\sin^2(2x)} = 1+2\sin(2x) - 2\cos(2x)
Using the identity \sin^2(x) + \cos^2(x) = 1, we can further simplify this to:
1+2\sin(2x) - 2\cos(2x) = 1+2\sin(2x) - 2\sqrt{1-\cos^2(2x)} = 1+2\sin(2x) - 2|\cos(2x)|
Now, we can rewrite the entire inequality as:
2\cos(x) \le 1+2\sin(2x) - 2|\cos(2x)| \le \sqrt{2}
Next, we can break this into two separate inequalities:
1) 2\cos(x) \le 1+2\sin(2x) - 2|\cos(2x)|
2) 1+2\sin(2x) - 2|\cos(2x)| \le \sqrt{2}
For the first inequality, we can use the identity \cos(2x) = 1-2\sin^2(x) to simplify it to:
2\cos(x) \le 1+4\sin^2(x) - 2|\cos(2x)|
Using the fact that \sin^2(x) \le 1, we can rewrite this as:
2\cos(x) \le 1+4 - 2|\cos(2x)| = 5-2|\cos(2x)|
For the second inequality, we can use the identity \cos(2x) = 1-2\sin^2(x) to rewrite it as:
1+4\sin^2(x) - 2|\cos(2x)| \le \sqrt{2}
Simplifying, we get:
4\sin^2(x) - 2|\cos(2x)| \le \sqrt{2}-1
Now, we can solve each of these inequalities separately. For the first inequality, we can see
FAQ: Find x in [0,2π] to Solve Inequality
How do I solve an inequality involving x in the range of [0,2π]?
To solve an inequality involving x in the range of [0,2π], you need to first isolate the variable x on one side of the inequality sign. Then, you can use the properties of inequalities and basic algebraic operations to solve for x. Remember to also take into account the given range of [0,2π] when solving the inequality.
What is the significance of the range [0,2π] in solving inequalities involving x?
The range [0,2π] represents the values that x can take in order to satisfy the given inequality. It is important to consider this range because it limits the possible solutions and helps in finding the correct solution for the inequality.
Can I use the same method to solve any inequality involving x in the range of [0,2π]?
Yes, the same method can be used to solve any inequality involving x in the range of [0,2π]. Just make sure to adjust the steps according to the specific inequality and its given range.
What happens if the given range is different from [0,2π]?
If the given range is different from [0,2π], then the method for solving the inequality involving x will also differ. You will need to take into account the new range and adjust the steps accordingly.
Are there any other factors to consider when solving an inequality involving x in the range of [0,2π]?
Yes, besides the given range, you should also consider the direction of the inequality (whether it is less than or greater than) and any restrictions on x (such as x cannot be negative). These factors will affect the final solution and should be taken into account when solving the inequality.
