Find x in Exponential Equation: 2^x=8x
  • MHB
  • Thread starter fasakintitus
  • Tags
    Exponential
In summary, to find the value of x when 2^x = 8x, numerical methods must be used as there is no exact solution. There will be two possible roots, one between 0 and 1 and the other between 5 and 6. The equation can be rewritten as x(1/2)^x = 1/8, then using the Lambert W function, x can be expressed as W(ln(1/2)/8)/ln(1/2), which requires a numerical method to find.
fasakintitus
Find x, if 2^x =8x.
Mathematics news on Phys.org
fasakintitus said:
Find x, if 2^x =8x.
You will have to use numerical methods to get approximate answers, as there is no exact solution able to be found.
There will be two roots, one between 0 and 1, the other between 5 and 6.
If \(\displaystyle 2^x= 8x\) then \(\displaystyle 1= 8x2^{-x}= 8x\left(\frac{1}{2}\right)^x\) so that \(\displaystyle x\left(\frac{1}{2}\right)^x= \frac{1}{8}\).
But \(\displaystyle \left(\frac{1}{2}\right)^x=\)\(\displaystyle e^{ln\left(\left(\frac{1}{2}\right)^x\right)}\)\(\displaystyle = e^{x ln(1/2)}\). If w let \(\displaystyle y= x ln(1/2)\) then \(\displaystyle x= \frac{y}{ln(1/2)}\) and the equation becomes \(\displaystyle \frac{y}{ln(1/2)}e^y= \frac{1}{8}\) or \(\displaystyle ye^y= \frac{ln(1/2)}{8}\).
Apply the "Lambert W function" (defined as the inverse function to \(\displaystyle f(x)= xe^x\)) to both sides to get \(\displaystyle y= W\left(\frac{ln(1/2)}{8}\right)\).
Then \(\displaystyle x= \frac{y}{ln(1/2)}= \frac{W\left(\frac{ln(1/2)}{8}\right)}{ln(1/2)}\).
Of course, your calculator probably doesn't have a "W" function key so you would have to use a numerical method to find that.
FAQ: Find x in Exponential Equation: 2^x=8x
1. What is the value of x in the exponential equation 2^x=8x?
In this equation, x can be solved by taking the logarithm of both sides. The value of x is approximately 2.079.
2. Is there a simpler way to solve this exponential equation?
Yes, there are multiple ways to solve this equation. One possible method is to rewrite the equation as 2^x = 2^3x and then equate the exponents. This yields the solution x=3.
3. Can this equation be solved without using logarithms?
Yes, as mentioned in the previous question, the equation can be solved by equating the exponents. Another method is to graph both sides of the equation and find the intersection point, which gives the solution of x=3.
4. Can this equation have more than one solution?
Yes, this equation can have multiple solutions. In addition to x=2.079 and x=3, there are also infinite complex solutions.
5. How is this exponential equation related to real-life situations?
Exponential equations are commonly used to model growth and decay in various fields such as finance, population growth, and radioactive decay. This specific equation can represent situations where the rate of increase is proportional to the current value, such as in compound interest.
