MHB Find x (Radians): Solve sec(2π/3 + x) = 2
  • Thread starter Thread starter eleventhxhour
    Radians
To solve the equation sec(2π/3 + x) = 2, it can be transformed into cos(2π/3 + x) = 1/2. This leads to the equation 2π/3 + x = kπ ± π/3, where k is an integer. By isolating x, the general solution can be expressed as x = kπ - 2π/3 ± π/3. The discussion highlights the importance of considering the range of the arc-cos function and the periodic nature of cosine when finding solutions. The conversation reflects uncertainty about expanding the solution set appropriately.
eleventhxhour
If sec(2pi/3 + x) = 2, what does x equal?
So far I changed it to cos by dividing 1/2. And then, I changed the 1/2 to radians which is pi/3. But, I'm not sure what to do next.
Mathematics news on Phys.org
If you are going to find the general solution, you could write:
$$x+\frac{2\pi}{3}=2k\pi\pm\frac{\pi}{3}$$
And then solve for $x$. :D
Also you can do it using your way
$$sec(\frac{2\pi}{3}+x)=2$$
$$\frac{1}{cos(\frac{2\pi}{3}+x)}= 2$$
then
$$cos(\frac{2\pi}{3}+x) = \frac{1}{2}$$
$$\frac{2\pi}{3}+x=kx\pi \pm \frac{\pi}{3}$$
solve for x now ..
How does that follow?
$$cos(\frac{2\pi}{3}+x)=\frac{1}{2}$$
$$cos^{-1}cos(\frac{2\pi}{3}+x)=cos^{-1}(\frac{1}{2})$$
$$\frac{2\pi}{3}+x=\frac{\pi}{3}$$
To here , I think I'm correct because the range of arc-cos function is
from zero to PI.
But cannot we expand it to be (2xPI + PI/3) "the solution set of cos function"?
I'm not sure
(Thinking)
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Is it possible to arrange six pencils such that each one touches the other five? If so, how? This is an adaption of a Martin Gardner puzzle only I changed it from cigarettes to pencils and left out the clues because PF folks don’t need clues. From the book “My Best Mathematical and Logic Puzzles”. Dover, 1994.
