Find y such that cos y=cos(90+y) and −90degrees <= y <= 0degrees?
  • Thread starter Thread starter iamsmooth
    Cos
To solve the equation cos y = cos(90+y) within the range of -90 degrees to 0 degrees, the correct approach involves using trigonometric identities. The identity cos(a+b) = cos(a)cos(b) - sin(a)sin(b) simplifies the equation to cos(y) = -sin(y). This leads to the conclusion that tan(y) = -1, resulting in y = -45 degrees. The discussion emphasizes the importance of memorizing key trigonometric values and identities for solving such problems effectively. Ultimately, the solution is confirmed as y = -45 degrees.
iamsmooth
cos(a+b)=sin(a)cos(b)+cos(a)sin(y)
This is a question that came up in my linear algebra class. We just learned about dot product, but this doesn't seem like it's related. It almost seems like a straight trig question.
Anyways, is this a trick question? Wouldn't the answer be 0 since you can't take the cosine of a negative number?
This is a straight trig problem, and isn't a trick question.
The answer is NOT zero; the cosine and sine functions are defined for all real numbers. Use your relevant equations to find the solution.
Okay, so plugged in:
cos y = sin(90)cos(y)+cos(90)sin(y)
cos(90) = 0 so that leaves
cos(y)/cos(y) = sin(90)
1 = sin(90), but that's already given...
I don't know what I'm doing... don't know how to do this if there's an unknown. What do I do from here :o?
Is it just simple algebra?
I'm stupid, sorry. I used the wrong identity ><
I got it
So what did you get for the solution?
cos(a+b) = cos(a)cos(b)-sin(a)sin(b)
So cos(90+y) = cos(90)cos(y)-sin(90)sin(y)
cos(y) = (0)cos(y) - (1)sin(y)
cos(y) = -sin(y)
1 = -sin(y)/cos(y)
sin(y)/cos(y) = -1
sin(y)/cos(y) = tan(y) = -1
tan(-45) = -1, so -45
I had to use a calculator to get the last part though. I guess I need to memorize my trig and unit circle at this point of linear algebra.
Yes, you should memorize the sine and cosine of 0, 30, 45, 60, and 90 degrees (0, pi/6, pi/4, pi/3, pi/2).
The next-to-last line you have is tan(y) = -1, so y = tan-1(-1) = -45 degrees. When you start with an equation with an unknown to find (y in this case), your last line should have the unknown in it; i.e., y = -45 degrees. Units are good, too.
