MHB Find Zeros of $2x^3+5x^2-28x-15$ with Synthetic Division
  • Thread starter Thread starter karush
The discussion focuses on finding the zeros of the polynomial function g(x) = 2x^3 + 5x^2 - 28x - 15 using synthetic division and the quadratic formula. Synthetic division reveals a factor of (x - 3), leading to a quadratic equation 2x^2 + 11x + 5. The correct application of the quadratic formula results in the roots x = -5 and x = -0.5. The final factorization of g(x) is presented as (x + 10)(x + 0.5)(x - 3). The importance of correctly applying the quadratic formula is emphasized throughout the discussion.
karush
MHB
$\text{factor}$
$g(x)=2x^3+5x^2-28x-15$
$\text{synthetic division}$
$\begin{array}{c|rr}
& 2 & 5 &-28 &-15 \\
&&6&33 & 15\\ \hline
3&2&11&5&0
\end{array}$
$\text{thus }\\$
$2x^2+11x+5$
$\text{use quadradic formula}$
$\begin{align*}
x=\frac{-(11)\pm\sqrt{(11)^2-4(2)(5)}}{2(1)}
&=\frac{-11\pm\sqrt{81}}{2}
=\frac{-11\pm9}{2}
\end{align*}$
$x=-10,-1 \quad g(x)=(x+10)(x+1)(x-3)$
hopefully
comment?
Mathematics news on Phys.org
Check your application of the quadratic formula, or simply factor. :)
a=2 not 1
$\begin{align*}
x=\frac{-(11)\pm\sqrt{(11)^2-4(2)(5)}}{2(2)}
&=\frac{-11\pm\sqrt{81}}{4}
=\frac{-11\pm9}{4}
\end{align*}$
$\text{then $x=-5,-\frac{1}{2}$
so
$g(x)=(x+10)(x+\frac{1}{2})(x-3)$}$
Thread 'Video on imaginary numbers and some queries'
Hi, I was watching the following video. I found some points confusing. Could you please help me to understand the gaps? Thanks, in advance! Question 1: Around 4:22, the video says the following. So for those mathematicians, negative numbers didn't exist. You could subtract, that is find the difference between two positive quantities, but you couldn't have a negative answer or negative coefficients. Mathematicians were so averse to negative numbers that there was no single quadratic...
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. In Dirac’s Principles of Quantum Mechanics published in 1930 he introduced a “convenient notation” he referred to as a “delta function” which he treated as a continuum analog to the discrete Kronecker delta. The Kronecker delta is simply the indexed components of the identity operator in matrix algebra Source: https://www.physicsforums.com/insights/what-exactly-is-diracs-delta-function/ by...
Thread 'Unit Circle Double Angle Derivations'
Here I made a terrible mistake of assuming this to be an equilateral triangle and set 2sinx=1 => x=pi/6. Although this did derive the double angle formulas it also led into a terrible mess trying to find all the combinations of sides. I must have been tired and just assumed 6x=180 and 2sinx=1. By that time, I was so mindset that I nearly scolded a person for even saying 90-x. I wonder if this is a case of biased observation that seeks to dis credit me like Jesus of Nazareth since in reality...
