Finding 12.7mm and 13mm dia wedge prisms
  • Thread starter Mike_In_Plano
  • Tags
    Wedge
In summary, the conversation is about finding a lens manufacturer that sells 12.7mm or 13mm dia wedge prisms. The person suggests checking out Alkor, a company that offers custom orders for fused silica or BK7 materials. They also mention that the company is located in Russia and that they have found other custom houses since. The conversation ends with a humorous reference to a bird that looks like the person responding.
Mike_In_Plano
702
35
Hello,
Can anyone give me a heads up for a lens manufacturer that sells 12.7mm or 13mm dia wedge prisms? It seems all my sources only have 25.4mm.
Thanks in advance,
Mike
It looks like Alkor will do this. It may be a custom order, but you could call them to find that out.
http://www.alkor.net/wedges.html
That page lists some rather exotic materials, but in the text they say they'll do fused silica or BK7 as well.
Note: I have never dealt with them before, nor heard of them before finding them in a google search just now.
EDIT: It looks like they are located in Russia. Not sure if that is a problem.
Thanks, Redbelly.
I've found a few custom houses since. On specializes in blanks and has the quote "Our world is flat."
PS - It seems I used to know a fellow that looked a lot like you and would come pecking into one of my old trees...
FAQ: Finding 12.7mm and 13mm dia wedge prisms
What are wedge prisms and how are they used in scientific research?
Wedge prisms are triangular prisms with one of the angles slightly tilted, creating a wedge-shaped cross-section. They are commonly used in scientific research for beam steering, laser alignment, and optical metrology. They can also be used for polarization control, light splitting, and wavelength tuning.
How do I determine the correct size for 12.7mm and 13mm diameter wedge prisms?
The size of a wedge prism is determined by its diameter and the angle of the wedge. For a 12.7mm and 13mm diameter wedge prism, the angle of the wedge should be around 2 degrees. However, the exact size will ultimately depend on your specific research needs and the equipment being used.
Can I use a wedge prism with different angles for my research?
Yes, wedge prisms are available in a variety of angles, ranging from 0.5 degrees to 10 degrees. The specific angle needed will depend on the application and the desired outcome. It is important to carefully consider the angle and size of the wedge prism to ensure it is suitable for your research needs.
How do I choose between a 12.7mm and 13mm diameter wedge prism?
The choice between a 12.7mm and 13mm diameter wedge prism will depend on the specific requirements of your research. The 13mm diameter will allow for a larger beam size, while the 12.7mm diameter will have a smaller footprint and may be more suitable for compact setups. It is important to consider the size and angle of the wedge prism to ensure the best fit for your research needs.
Where can I find 12.7mm and 13mm diameter wedge prisms for purchase?
Wedge prisms can be purchased from a variety of scientific equipment suppliers and manufacturers. It is important to carefully research and compare options to find the best quality and price for your specific needs. Online marketplaces and scientific equipment trade shows can also be good resources for finding and purchasing wedge prisms.
