Finding a and d from the Sum of an Arithmetic Series
In summary: The next four terms of an arithemetic series are:$$a+d, a+2d, a+3d, a+4d$$So the sum of the next four terms is 115.
AN630078
242
25
Hello, I been revising sequences and series and have found the problem below. I normally do not struggle too much with these problems but the wording has confused me a little. I have approached question 1 in two ways but I do not think that either is necessarily correct. I would very much appreciate if anyone could comment upon my workings or offer any guidance 😁
An arithmetic series has first term a, and common difference d. The sum of the first four terms is 139 and the sum of the next four terms is 115.
Question 1: Find the values of a and d
Question 2: Find the value of n for which the nth term is the last positive term in the series.
Sn=1/2n(2a+(n-1)d
un=a+(n-1)d
Question 1; Method 1
If the sum of the first four terms is 139 then S4=139
139=1/2(4)(2a+(4-1)d)
139=2(2a+3d)
139=4a+6d----- [1]
The part of this question that is confusing is the "the sum of the next four terms is 115".
Would this mean that S8=S4+115=139+115=254?
In which case;
254=1/2(8)(2a+(8-1)d)
254=4(2a+7d)
254=8a+28d----- [2]
Subtract [2] from 2*[1] (multiply [1] by 2 so the values of a are the same)
8a+12d=278
8a+28d=254
-16d=24
d=-1.5
When d=-1.5, substitute into [1] to find a:
4a+(6*-1.5)=139
4a-9=139
4a=148
a=37
Method 2
Again if the sum of the first four terms is 139 then S4=139
139=2(2a+3d)
139=4a+6d----- [1]
However, would the sum of the next four terms actually mean S8-S5 inclusive?
In which case 115=S8-S5
115=1/2(8)(2a+(8-1)d)-1/2(5)(2a+(5-1)d)
115=4(2a+7d)-2.5(2a+4d)
Expand the brackets:
115=8a+28d-5a-10d
115=3a+18d ----- [2]
Subtract [2] from 3*[1] (multiply by 3 so the d terms are the same)
3*139=4a+6d becomes 417=12a+18d
12a+18d=417
2a+18d=115
10a=302
a=30.2
Substitute a into [1] to find d:
4a+6d=139
(4*30.2)+6d=139
120.8+6d=139
6d=18.2
d~3.03
I think the results of my second method are more unlikely but I have seen the approach of taking a sum of terms in a series to be e.g. between the sum of the first eight terms and first five terms inclusive.
Question 2; So, I do not think I can adequately solve this until I have firmly found the values of a and d.
However, would I be looking for when the nth term of the series being un=a+(n-1)d is >0
un>0
So I would remove the inequality sign to instead solve the equation
0=a+(n-1)d
If, the common difference is indeed -1.5 and the first term 37 then:
0=37+(n-1)-1.5
-37=-1.5(n-1)
-37/-1.5=n-1
n=24.67+1
n ~ 25.67
When n= 25, u25=37+24*-1.5=1
When n=26, u26=37+25*-1.5=-0.5
So would the last positive term of the series be 1 when the nth term of the series is 25?
Do either of my solutions show potential for an appropriate approach in comprehensively solving this problem.
Your first approach using ##S_8 - S_4## is the correct one. It might help you to write it explicitly:$$\begin{align*}S_4 &= u_1 + u_2 + u_3 + u_4 \\ \\ S_8 &= (u_1 + u_2 + u_3 + u_4) + (u_5 + u_6 + u_7 + u_8)\\ \\ S_8 - S_4 &= u_5 + u_6 + u_7 + u_8\end{align*}$$I haven't looked through all of your algebra, but I would have thought you can just use$$ \begin{align*}S_4 = 2(2a + 3d) &= 4a + 6d = 139 \\ \\ S_8 - S_4 = 4(2a + 7d) - 2(2a + 3d) &= 4a + 22d = 115 \end{align*}$$And then subtract the two equations:$$16d = -24 \implies d = -3/2, a = 37$$
Yes!
The first eight terms of an arithemetic series are:
$$a, a+d, a+2d, a+3d, a+4d, a+5d, a+6d, a+7d$$
Where is the confusion over which are the first four terms and which are the next four?
Related to Finding a and d from the Sum of an Arithmetic Series
1. What is an arithmetic series?
An arithmetic series is a sequence of numbers where the difference between any two consecutive terms is the same. This difference is called the common difference (d).
2. How do I find the sum of an arithmetic series?
The sum of an arithmetic series can be found using the formula Sn = n/2[2a + (n-1)d], where Sn is the sum, n is the number of terms, a is the first term, and d is the common difference.
3. Can I find a and d if I know the sum of an arithmetic series?
Yes, you can find a and d if you know the sum of an arithmetic series. Rearrange the formula Sn = n/2[2a + (n-1)d] to solve for a and d.
4. What if I only know the first and last term of an arithmetic series?
If you know the first and last term of an arithmetic series, you can use the formula d = (an - a1)/(n-1) to find the common difference. Then, you can use this value of d to find the sum of the series.
5. Can I use the formula for finding a and d for any type of arithmetic series?
Yes, the formula for finding a and d can be used for any type of arithmetic series, whether it is a finite series or an infinite series.
