Finding a basis for the null space and range of a matrix
In summary, we have a linear transformation S with a matrix representation of$$\left(\begin{array}{cc}1 & -1\\1 & -1\\\end{array}\right)$$and a basis for the null space is (1,1). The range of S is a one-dimensional space and any vector not in the null space can serve as a basis for the range. The columns (1,0) and (-1,0) of the matrix are also a basis for the range.
DeadOriginal
274
##S## is a linear transformation and ##\{u_{1},u_{2}\}## is a basis for the vector space.
S(u_{1})=u_{1}+u_{2}\\
S(u_{2})=-u_{1}-u_{2}
I would like to find a basis of the null space and range of ##S##.
In my text, it says that the proper matrix representation of ##S## is
1 & -1 \\
1 & -1 \\
\end{array}\right).
I understand that this way of representing S with a matrix will preserve equality when we compose two linear transformations in matrix from but it is confusing me. I found a supposed basis for the null space as follows. I first put the matrix in echelon form:
1 & -1 \\
1 & -1 \\
\end{array}\right) \rightarrow \left(\begin{array}{cc}
1 & -1 \\
0 & 0 \\
\end{array}\right).
Then we are left with the equation ##x_{1}-x_{2}=0## so any vector in the null space has the form ##(\lambda,\lambda)## where ##\lambda## is an arbitrary number. From the definition of the null space we should have that ##S\cdot(\lambda,\lambda)=0## and this holds when I put ##(\lambda,\lambda)## into column form and multiply it by the matrix of ##S## but when I try to plug ##(\lambda,\lambda)## into ##S(u_{1},u_{2})=(u_{1}+u_{2},-u_{1}-u_{2})##, things don't seem to work out anymore. Did I do something wrong when finding the basis or am I thinking about the null space in the wrong way?
I would also like help on finding a basis for the range. I know that it is the same as a basis for the column space but again, do I use the columns in the matrix of ##S## as I have defined it above?
1 & -1 \\
1 & -1 \\
\end{array}\right).
1 & -1 \\
1 & -1 \\
1 & -1 \\
0 & 0 \\
\end{array}\right).
The book's statement of the matrix for S is clearly wrong. What do you think it should be?
I thought that the matrix of ##S## should be presented by
1 & 1 \\
-1 & -1 \\
\end{array}\right)
but the texts main reason behind why this was wrong was because say we had another linear transformation T defined by the equations
T(u_{1})=2u_{1}+u_{2}\\
T(u_{2})=u_{1}-u_{2}
then we will have the matrix representation for ##T## as
2 & 1 \\
1 & -1 \\
\end{array}\right)
Then the linear transformation ST would be defined as
ST(u_{1})=S(T(u_{1}))=S(2u_{1}+u_{2})=2(u_{1}+u_{2})-u_{1}-u_{2}=u_{1}+u_{2}\\
ST(u_{2})=S(T(u_{2}))=S(u_{1}-u_{2})=u_{1}+u_{2}-(-u_{1}-u_{2})=2u_{1}+2u_{2}
which would then have a matrix representation of
1 & 1 \\
2 & 2 \\
\end{array}\right).
We should get the same matrix if we multiplied the matrix of ##S## and ##T##:
1 & 1 \\
-1 & -1 \\
\end{array}\right)\left(\begin{array}{cc}
2 & 1 \\
1 & -1 \\
\end{array}\right)=\left(\begin{array}{cc}
3 & 0 \\
-3 & 0 \\
\end{array}\right).
On the other hand, if we represented the matrices the way the book wants them we have the matrix for ##S## as
1 & -1 \\
1 & -1 \\
\end{array}\right)
and the matrix for ##T## as
2 & 1 \\
1 & -1 \\
\end{array}\right).
Multiplying these gives us
1 & -1 \\
1 & -1 \\
2 & 1 \\
1 & -1 \\
1 & 2 \\
1 & 2 \\
\end{array}\right)
which would be our composed transformations represented as a matrix the way the book wants it.
First, I'm willing to work with [tex]S = \begin{pmatrix}
1 & -1\\
1 & -1
\end{pmatrix}[/tex]
But I cannot make any sense out of S(u1) = u1 + u2S(u2), because the first term is a vector and the second term is a scalar. There may be a typo here. So let's work with the matrix.
You already concluded that the null space are all the vectors of the form (a,a). Another way of writing that is a(1,1) and (1,1) is the basis of your nullspace. Observe that this is a 1 dimensional space, which matches up nicely with the fact that your echelon form has just one zero row.
Re the basis for the range the easiest approach in this case is to notice that the range and nullspace taken together are the entire space, which is two dimensional. The range is also a one dimensional space, so any vector whatsoever that is not in the nullspace is a basis for the range.
The column space is clear in the echelon form of the matrix. It consists of two vectors, (1,0) and (-1,0) which you can see are not independent since the first is just -1 times the second. You can use either of these vectors as your basis for the column space, and they certainly will do as the basis for the range.
So let u1 = (1,1). From the matrix definition S(u1) = (1-1, 1-1) = (0,0) which is what you should be getting since (1,1,) is a basis for the nullspace. We took u2 = (1,0) so S(u2) = (1,0).
As long as S(u2) is in the range and not the null space -- as is evidently the case -- I'm happy.
I fixed the typo. Sorry about that.
I understand everything but this part. In particular, how do you have S(u1) = (1-1, 1-1)?
This is not true. If you take an arbitrary vector (x,y) and multiply it by the matrix of S, you get
$$\begin{pmatrix} 1 & -1 \\ 1 & -1 \end{pmatrix}\begin{pmatrix} x \\ y \end{pmatrix} = \begin{pmatrix} x-y \\ x-y \end{pmatrix}$$ You should be able to see by inspection what a basis for the range is.
Yes, you are right. A basis for the range is also (1,1). The (1,0) or any vector independent of (1,1) is the basis for the subspace of vectors such that [tex] Sx \ne 0[/tex] i.e. those that are not in the nullspace and will thus get mapped into the range. Sorry I mixed them up.
I am little confused. Is the textbooks way of representing ##S## correct?
Yes, it is. You can find the columns of the matrix of a transformation by applying it to the basis vectors. In this case, you had
$$S(\vec{u}_1) = \vec{u}_1 + \vec{u}_2.$$ In matrix notation, this would correspond to the equation
$$S\begin{pmatrix} 1 \\ 0 \end{pmatrix} = \begin{pmatrix} 1 \\ 1 \end{pmatrix}.$$ If you don't already see it, you should convince yourself that multiplying a matrix by the vector (1,0) picks off the first column of the matrix. So this says the first column is (1,1).
Ahh! Ok. That makes sense.
Related to Finding a basis for the null space and range of a matrix
1. What is the null space of a matrix?
The null space of a matrix is the set of all vectors that, when multiplied by the matrix, result in a zero vector. In other words, it is the set of all solutions to the equation Ax = 0, where A is the matrix and x is a vector.
2. How do you find the basis for the null space of a matrix?
To find the basis for the null space of a matrix, you can use row reduction to put the matrix in reduced row echelon form. The columns that correspond to the pivot positions in the reduced matrix form a basis for the null space.
3. What is the range of a matrix?
The range of a matrix is the set of all possible outputs when the matrix is multiplied by a vector. In other words, it is the set of all vectors that can be obtained by multiplying the matrix by some vector.
4. How can you find the basis for the range of a matrix?
To find the basis for the range of a matrix, you can use row reduction to put the matrix in reduced row echelon form. The columns that correspond to the pivot positions in the original matrix form a basis for the range.
5. What is the relationship between the null space and range of a matrix?
The null space and range of a matrix are complementary subspaces. This means that every vector in the null space is orthogonal to every vector in the range, and vice versa. Additionally, the dimension of the null space plus the dimension of the range equals the number of columns in the matrix.
