Finding a Counterexample to a Wrong Statement about Limits
vibha_ganji
The number L is the limit of ƒ(x) as x approaches c if, given any epsilon greater than 0, there exists a value of x for which lƒ(x) - Ll is less than epsilon.
lf(x)-Ll < epsilon
I’m complete stuck on this problem. I am not sure how to start to find a counterexample to this statement.
another way is:
1. let ##f=x##
2. show that the limit of ##f## at ##a## is ##b##, where ##b\neq a##, by finding an ##x## such that ##|f(x)-b|<\epsilon##
3. conclude that the statement is false
vibha_ganji said:
Homework Statement:: The number L is the limit of ƒ(x) as x approaches c if, given any epsilon greater than 0, there exists a value of x for which lƒ(x) - Ll is less than epsilon.
Relevant Equations:: lf(x)-Ll < epsilon
Do you think it might be a valid definition of a limit? If not, why not? What's wrong with it?
You need to see what's wrong with that definition, and then you can find a counterexample.
This is a homework problem, so we can only give hints and redirection to the work that you show us.
For counterexamples, look for functions that "wiggle around widely and very rapidly" as it approaches a point. There will be a sequence of x values that approach that point and whose function values are the same, but it wiggles around so that another sequence of x values approaches the same point and all have a second function value.
Does this 'definition' actually require x to be anywhere near c?
Your relevant equations section should really have included the actual definition of a limit.
  • Love
Likes FactChecker, docnet and PeroK
Thread 'Use greedy vertex coloring algorithm to prove the upper bound of χ'
Hi! I am struggling with the exercise I mentioned under "Homework statement". The exercise is about a specific "greedy vertex coloring algorithm". One definition (which matches what my book uses) can be found here: https://people.cs.uchicago.edu/~laci/HANDOUTS/greedycoloring.pdf Here is also a screenshot of the relevant parts of the linked PDF, i.e. the def. of the algorithm: Sadly I don't have much to show as far as a solution attempt goes, as I am stuck on how to proceed. I thought...
