Finding a formula for displacement of a mass on a spring using v.
The discussion revolves around deriving the formula for displacement of a mass on a spring using velocity. The user starts with the energy conservation equation 1/2mv^2 = 1/2kx^2 and derives v^2 = mg^2/k but struggles to progress further. Key insights include the distinction between vertical and horizontal spring systems, emphasizing that at equilibrium, x=0 and v equals the maximum velocity. The conversation highlights that there is no standard equation for this scenario, but references to energy conservation principles are made. Ultimately, the focus is on finding the maximal displacement from the equilibrium position, also known as amplitude.
hamishmidd
A mass m is hung from a spring with spring constant k. The mass is kicked upwards such
that it has a speed of v when the mass is at the equilibrium position. What is the maximal displacement of the mass from the equilibrium position as the mass subsequently
oscillates?
Ek=1/2mv^2, U=1/2kx^2, kx=mg (at equilibrium position)
I have tried to answer this using the relevant equations I am provided on my formula sheet, however I get stuck pretty close to the end. I start with 1/2mv^2=1/2kx^2 at the equilibrium position, and kx=mg, x=mg/k. This gets me to v^2=mg^2/k, but I don't know where to go from there. The potential answers are:
(A) x = v*sqrt(m/k) (B) x =v^2/2g (C) x =sqrt(2mv/k) (D) x = vt +1/2gt^2 (E) None of the above
A vertical spring-mass system oscillates about its equilibrium position exactly like a horizontal spring-mass system. The only difference is that the vertical spring is at equilibrium when the spring is stretched by ##\Delta x=mg/k## whilst the horizontal spring is not stretched at equilibrium.
Answer this question as if you had a horizontal spring. Note that you are asked to find the maximal displacement from the equilibrium position. What is another name for it?
Further to @kuruman's advice, I'll point out that there is no such standard equation.
There's ##1/2mv_{max}^2=1/2kx_{max}^2##, and there's ##1/2mv^2(t)+1/2kx^2(t)=E##, where x is displacement from equilibrium.
At equilibrium, ##x=0, v=v_{max}##.
Thread 'Trying to understand the logic behind adding vectors with an angle between them'
My initial calculation was to subtract V1 from V2 to show that from the perspective of the second aircraft the first one is -300km/h. So i checked with ChatGPT and it said I cant just subtract them because I have an angle between them. So I dont understand the reasoning of it. Like why should a velocity be dependent on an angle? I was thinking about how it would look like if the planes where parallel to each other, and then how it look like if one is turning away and I dont see it. Since...
