Finding a fraction using series.
In summary: BIn summary, the conversation discusses ways to find the fraction closest to 0.987654321 using the geometric series. One method is to factor out 10^-9 and write the remaining factor as a sum of ascending powers of 10. Another method is to use continued fractions, which involves inverting, subtracting, and finding the integer parts to get a rational approximation.
misogynisticfeminist
370
How do i find the fraction closest to 0.987654321 using the geometric series?
I have tried taking the geometric series and its derivatives but none seem to fit it. Can anyone help?
Is that supposed to be a repeating decimal?
If it's not a repeating decimal then you want to factor out [itex]10^{-9}[/itex] then write the remaining factor as a sum of ascending powers of 10 and your earlier proposed method will give you the desired result.
[tex]0.987654321 = \frac{987654321}{1000000000}[/tex]
That's all. There's no sense in using geometric progression here, because it's a terminating decimal.
OTOH,
[tex]0.\bar{9}8765432\bar{1} = 987654321*\Sigma_{i=1}^{i=\infty}(10^{-9i})[/tex]
and you can then work out the summation with the formula for the sum of a geometric series.
There is a method of finding rational approximations to real numbers called "continued fractions". You can do it on your calculator. I will illustrate:
0.9876543210 invert and get
1.0125000000 subtract 1 to get
.01250000000 invert and get
80.000000064 subtract 80 to get
.000000064 invert to get
15625000.000 subtract 15625000 to get
This sequence terminated, which won't happen for an irrational number like sqrt(2) or pi.
The important sequence is the numbers are the things you subtracted, which were the integer parts of the numbers. The sequence is:
1, 80, 15625000
One can get a good fractional approximation by reversing the process. Since 15625000 is so big, I'll start with the "80". The reversed process (in rational numbers) is:
80
1/80
1+1/80 = 81/80
80/81.
So a darned good fractional answer is 80/81.
This is a very general algorithm. let me think a minute and I'll try and figure out how to do it with the geometric series and I'll edit that solution in.
[tex]\frac{1-x^n}{1-x} = 1 +x + x^2 + ... + x^{n-1}[/tex]
differentiate with respect to x get:
[tex]\frac{1-x^n}{(1-x)^2} - \frac{nx^{n-1}}{1-x}
= 1 + 2x + 3x^2 + ... + (n-1)x^{n-2}[/tex]
Now put x = 0.1 and n-1=9. The right hand side will become 1.23456789 and you can get what you want with some artful subtraction and multiplication by constants. But I haven't worked it out to see if it gives the same answer as the continued fraction expansion (i.e. 80/81).
Carl
FAQ: Finding a fraction using series.
What is a fraction series?
A fraction series is a sequence of fractions that follow a specific pattern or rule. Each fraction in the series is related to the previous fraction in some way.
How do I find a fraction using a series?
To find a fraction using a series, you need to first identify the pattern or rule that the series follows. Then, you can use this pattern to determine the next fraction in the series.
Can fractions be expressed as a series?
Yes, fractions can be expressed as a series by following a specific pattern or rule. For example, the series 1/2, 1/4, 1/8, 1/16, ... follows the pattern of dividing the previous fraction by 2.
What is the purpose of finding fractions using series?
The purpose of finding fractions using series is to have a systematic way of generating fractions that follow a specific pattern. This can be useful in various mathematical and scientific applications, such as in calculating probabilities or creating visual representations of fractions.
Are there any shortcuts for finding fractions using series?
Yes, there are some common patterns and rules that can be used as shortcuts for finding fractions using series. These include multiplying or dividing by a certain number, adding or subtracting a constant, or using a geometric or arithmetic progression.
