Finding a higher order derivative of a trig function
In summary, to find the 73rd derivative of f(x) = sin(2x) + 3, we can use the pattern of alternating sin and cos terms every other derivative and the formula for the nth derivative of sine, \sin^{(n)}(x)=\frac{d^n}{dx^n}\sin(x)=\sin(x+\frac{\pi}{2}n), to determine that the 73rd derivative will be 2^73cos2x. Additionally, using the chain rule, \frac{d^n}{dx^n}f(a x)=a^n f^{(n)}(a x), we can eliminate the shift and see that the 73rd derivative is a repeat of earlier derivatives
tmlrlz
29
Find the 73rd derivative of f(x) = sin(2x) + 3
(Hint: Take the first five derivatives to find a pattern)
dy/dx
I took the first five derivatives to find the pattern:
dy/dx = 2cos2x
d2y/dx2 = -4sin2x
d3y/dx3 = -8cos2x
d4y/dx4 = 16sin2x
d5y/dx5 = 32cos2x
Now if we look at the pattern we can see that every odd term derivative will result in tcos2x and every even term derivative will result in tsin2x where t is an element of all integers.
If we just look at the value of t and not the sign, let's say we are focusing on |t|, then we just look at the pattern and figure out that it will be 2^73 because each of the terms are multiplied by 2^n where n in this case is 73. Now if we were looking at the sign we notice that it alternates: (every underlined term number will be a negative derivative, otherwise it will be a postive derivative)
1 , 2 , 3 , 4 , 5 , 6 , 7 , 8 , 9 , 10
11 , 12 , 13 , 14 , 15 , 16 , 17 , 18 , 19 , 20
21, 22 , 23
31, 32 , 33
41, 42 , 43
51, 52 , 53
61, 62 , 63
71, 72 , 73
A pattern starts after the 20th term because then the cycle repeats and by this we know that the 73rd derivative will be a positive derivative so a positive t, thus the 73rd derivative is 2^73cos2x.
I am fairly sure that my answer is correct, however i do not think that my process and explanation are sufficient enough mathematically to show my answer. Can you please help in finding a general formula for this or perhaps a more mathematical way of finding the derivative, especially for the part where i was determining the sign (positive,negative) of the derivative. Thank you.
I don't think the sign pattern should have changed at the 20th derivative. It should remain a cycle of four.
sin(n)(x)=sin(x+n π/2)
(f(ax+b))(n)=anf(n)(ax+b)
and write 73=4*18+1
and write 73=4*18+1
I am still confused about what you mean, is this the general formula to finding the derivative of this function to any number and you plug in 73 for n? Also sin(x+n π/2)? is it n * n/2 or n + n/2? Please go over your post in more detail because i do not understand how to apply any of the equations you wrote or what they mean. Thank you.
tmlrlz: It looks like you're on the right track. I agree with the 2^73 part. How did you get that the pattern changes after the 20th derivative? It would certainly seem odd to me if the pattern just changes for no apparent reason after the 20th derivative. I mean, the sign changes happen because of the way the derivatives of sin and cos work.
When i was writing down the terms i thought that it repeated after 20 terms but someone pointed out that it repeats after four terms. however i just don't know how to make this answer seem more mathematical, like a formula for the derivative that i could plug in 73 and get out the 73rd derivative because the alternating cos and sin as well as the pattern of positives an negatives
i think there are 3 parts, like you mentioned: the sign, whether it's sin or cos, and what the number in front of the sin/cos is (disregarding the sign). You've already figured out the number (2^73). The pattern for sin/cos is: cos, sin, cos, sin, cos, sin... And I think you found the pattern for the sign too. Does that help?
Yes that is the general equation for the nth derivative of sine the second thing is pi, not another n.
[tex]\sin^{(n)}(x)=\frac{d^n}{dx^n}\sin(x)=\sin(x+\frac{\pi}{2}n)[/tex]
The second thing is the chain rule
[tex]\frac{d^n}{dx^n}f(a x)=a^n f^{(n)}(a x)[/tex]
Your question can be answered by combining these two. Also as has been mentioned there is a repeating pattern, 73=18*4+1 so the 73 derivative is a repeat of earlier ones.
I don't understand how you would combine these two to get a formula for the derivative. If you plug in 73 it doesn't turn out to be the same thing and how does it show that sin and cos alternate every other term and the pattern of the positives and negatives? I'm sorry, I'm sure that what you're saying is correct, i just do not understand. Thank you.
combine them like
[tex]\frac{d^n}{dx^n}\sin(a x)=a^n \sin^{(n)}(a x)=a^n \sin(a x+\frac{\pi}{2}n)[/tex]
We can also eliminate the shift if desired
[tex]\sin^{(101)}(x)=\frac{d^{101}}{dx^{101}}\sin(x)= \sin(x+\frac{\pi}{2}101)= \sin(x+25*2\pi+\frac{\pi}{2})=\sin(x+\frac{\pi}{2})=\cos(x)[/tex]
[tex]\sin^{(1003)}(x)=\frac{d^{1003}}{dx^{1003}}\sin(x)=\sin(x+\frac{\pi}{2}1003)= \sin(x+250*2\pi+3\frac{ \pi }{2})=\sin(x+3\frac{\pi}{2})=-\cos(x)[/tex]
Related to Finding a higher order derivative of a trig function
1. What is a higher order derivative?
A higher order derivative is a mathematical concept that refers to the derivative of a function that has already been derived. In other words, it is the derivative of a derivative. It measures the rate of change of the rate of change of a function.
2. How do you find a higher order derivative of a trigonometric function?
To find a higher order derivative of a trigonometric function, you need to use the chain rule. This means that you need to take the derivative of the outer function and then multiply it by the derivative of the inner function. For example, to find the second derivative of sin(x), you would take the derivative of sin(x) (which is cos(x)) and then multiply it by the derivative of x (which is 1), resulting in the second derivative of sin(x) being cos(x).
3. What is the purpose of finding a higher order derivative?
The purpose of finding a higher order derivative is to analyze more complex functions. It allows us to understand the rate of change of the rate of change of a function, which can provide insights into the behavior of the function. Higher order derivatives are also used in optimization and in solving differential equations.
4. Can a higher order derivative be negative?
Yes, a higher order derivative can be negative. This means that the function is decreasing at an increasing rate. For example, the second derivative of a concave down function will be negative.
5. Are there any shortcuts for finding higher order derivatives of trigonometric functions?
Yes, there are some shortcuts for finding higher order derivatives of trigonometric functions. For example, the nth derivative of sin(x) can be found using the formula (-1)^n * sin(x) or cos(x) for even or odd values of n, respectively. Additionally, there are tables of derivatives that can be used to find higher order derivatives of trigonometric functions without having to use the chain rule.
