MHB Finding a Ratio for Linear Recurrence Sequences
The discussion revolves around understanding linear recurrence sequences, specifically how to find ratios between terms when they appear inconsistent. The user presents a sequence and expresses confusion about calculating terms based on a given recurrence relation, U(n+1) = -0.3U(n) + 3, starting with U1 = 2. Another participant clarifies the recurrence relation and provides calculated terms, indicating that the sequence approaches a stable value. The user seeks further clarification on the recurrence relation and its implications for understanding the sequence's behavior.
Casio1
I have a linear recurrence sequence and am having a problem understanding what to do when the ratio does not seem to be the same between each of the terms, so
Terms;
4, 1.4, 2.44, 2.024... (n = 1,2,3...)
How do I find a the ratio of these terms, and if there is none, please advise how I continue?
Kind regards
Casio:confused:
Mathematics news on Phys.org
Terms;
Kind regards
Casio:confused:
Could you tell us what the recurrence relation is?
CB
CB
U1 = 2, Un+1 =-0.3Un + 3 (n = 1,2,3...)
U2= U2.4+1 = -0.3(3.4) + 3 = 1.98
U3 = U1.98+1 = -0.3(2.98)+3 = 2.11
U4 = U2.11+1 = -0.3(3.11)+3 = 2.07
Four terms are;2, 1.98, 2.11, 2.07,...
Not sure whether the first method I used to work out the terms was correct, or whether the method I used here is correct, the course book does not give any examples to show how they are done, only examples to solve?
Thanks
Casio
Thanks
Casio
What are you being asked to do with this sequence?
It obviously has an attractor at u=30/13, increasing towards it if it starts at less than 30/13 and decreasing towards it if it starts above.
CB
Hello, Casio!
You are misunderstanding the recurrence relation.
\text{Given: }\:U_{n+1} \:=\:-0.3U_n + 3,\;\;U_1 = 2
We have:
. . . \begin{array}{cccccc}U_1 &=& 2 \\ U_2 &=& -0.3(2) + 3 &=& 2.4 \\ U_3 &=& -0.3(2.4) + 3 &=& 2.28 \\ U_4 &=& -0.3(2.28) + 3 &=& 2.316 \\ \vdots && \vdots && \vdots \end{array}
soroban said:
Hello, Casio!
We have:
Thanks for setting me on the right line of thought there.
OK let me take this one step at a time so I get the proper understanding of what is actually going on with these sequences.
First, please explain what this part refers to;\text{Given:}\:U_{n+1}
Casio
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
