Finding a relationship between functions
In summary, the conversation discusses two exponential equations, each described by a different variable (n and v). The end constants are considered negligible, leading to two simplified equations. The speaker is trying to find a relationship between n and v and has attempted to transform the equations into linear form. They are seeking suggestions for finding a numerical relationship and questioning the value of finding the intersection of the two linear equations. The validity of considering certain constants as negligible is also questioned.
impendingChaos
24
I posted on this tangent a little while ago but I've moved forward and was looking for some input.
I have two exponential equations each is described by a different variable (n and v respectively):
y=1.44E-24*exp(46.22n)+2.006E-8
y=2.88*exp(-2.4v)-3.009E-5
Since the end constants are so small I am considering them negligible so:
y=2.88*exp(-2.4v)
What I am trying to find is a relationship between variables n and v.
Currently I've tried taking the natural log of both sides to get:
ln(y)=ln(1.44E-24)+ln(exp(46.22n))
ln(y)=-54.897+56.22n
and
ln(y)=ln(2.88)+ln(exp(-2.4v))
ln(y)=1.058-2.4v
So in essence I now have two linear equations. Are there any suggestions to finding a numerical relationship between n and v. Is there value in finding the intersection of these two linear equations?
Thanks
C.N.
Mathematics news on Phys.org
If you don't mind me saying so, there is something odd in you asserting that things of the order 10^-5 are negligible, but that 10^-24 isn't.
y=something
y=something else
therefore something equals something else. That is a relation ship. It just isn't of the (unjustifiable preferred?) v=function of n.
Hi C.N.,
Thank you for sharing your progress and asking for input on finding a relationship between your two exponential equations. It looks like you've made some good progress so far by simplifying your equations and taking the natural log of both sides.
One suggestion I have is to plot your two equations on a graph and see if you notice any patterns or similarities. This can help you visually see if there is a relationship between n and v. You can also try plugging in different values for n and v and see if there is a consistent relationship between the resulting y values.
Another approach you could try is to solve for one variable in terms of the other in each equation. For example, in the first equation, you could solve for n by dividing both sides by 1.44E-24 and then taking the natural log, giving you n = (ln(y) + 54.897)/56.22. Then, in the second equation, you could solve for v in terms of n by dividing both sides by 2.88 and taking the natural log, giving you v = (ln(y) - 1.058)/(-2.4). Now, you have both n and v expressed in terms of y, which may help you see a relationship between n and v.
As for the value in finding the intersection of the two linear equations, it could potentially give you a specific value for n and v that satisfies both equations. However, it may not necessarily give you a clear relationship between the two variables.
I hope this helps and good luck with your exploration! Keep experimenting and you may discover a relationship between n and v that you hadn't thought of before.
FAQ: Finding a relationship between functions
What is the definition of a function?
A function is a mathematical relation between two sets of values, where each input value (independent variable) is assigned a unique output value (dependent variable). In other words, a function is a rule that relates one set of numbers to another set of numbers.
How do you find the domain and range of a function?
The domain of a function is the set of all possible input values, and the range is the set of all possible output values. To find the domain, you need to identify any restrictions on the input values, such as division by zero or taking the square root of a negative number. To find the range, you can analyze the behavior of the function and its graph, or use algebraic methods such as finding the maximum and minimum values.
What is the process for graphing a function?
To graph a function, you first need to determine the domain and range. Then, you can plot several points by substituting different values for the input variable and finding the corresponding output values. These points can be connected to create a smooth curve, which represents the graph of the function. It is also helpful to identify any important features of the graph, such as intercepts, asymptotes, and symmetry.
How do you determine if two functions are equivalent?
Two functions are equivalent if they have the same domain, range, and output for every input value. This means that they produce the same result for every possible input. To determine if two functions are equivalent, you can compare their algebraic expressions, graphs, or tables of values.
What is the purpose of finding a relationship between functions?
Finding a relationship between functions allows us to understand and analyze how different quantities are related to each other. This can be useful in various fields such as science, economics, and engineering. By studying the relationship between functions, we can make predictions, solve problems, and make informed decisions based on the data and patterns we observe.
