MHB Finding a set of vectors that span u,v....
  • Thread starter Thread starter shamieh
    Set Span Vectors
shamieh
Find a set of vectors {u, v} in $\mathbb{R}^4$ that spans the solution set of the equations:
$x - y + 2z - 2w = 0$
$2x + 2y -z + 3w = 0$
($u$ and $v$ are both $4 \times 1$)
$u = ?$, $v = ?$
I put the matrix in RREF to get
$\begin{bmatrix}1&0&3/4&-1/4\\0&1&-5/4&7/4\end{bmatrix} = \begin{bmatrix}0\\0\end{bmatrix}$
Then I got $x = -\frac{3}{4} z + \frac{1}{4} w$ and $y = \frac{5}{4} z - \frac{7}{4} w$
But I'm not sure how to present the answer as they want it.
You have what are called "two free variables" (in this case, $z$ and $w$, which must be known to even calculate what $x$ and $y$ are).
Let's write the solutions in a slightly different way, we have:
$4x = -3z + w$
$4y = 5z - 7w$
so we can write $4(x,y,z,w) = (4x,4y,4z,4w) = (-3z+w,5z-7w,4z,4w) = z(-3,5,4,0) + w(1,-7,0,4)$
Maybe this will give you a hint.
Thread 'Derivation of equations of stress tensor transformation'
Hello ! I derived equations of stress tensor 2D transformation. Some details: I have plane ABCD in two cases (see top on the pic) and I know tensor components for case 1 only. Only plane ABCD rotate in two cases (top of the picture) but not coordinate system. Coordinate system rotates only on the bottom of picture. I want to obtain expression that connects tensor for case 1 and tensor for case 2. My attempt: Are these equations correct? Is there more easier expression for stress tensor...
