Finding a5 in an+1 Sequence Using a4 and 1/2
  • MHB
  • Thread starter brunette15
  • Tags
    Sequence
In summary: Thus, in summary, to find the closed form for the given difference equation, we first find the homogeneous solution and particular solution, then use the principle of superposition to obtain the general solution. Finally, we use the given initial value to solve for the parameter and write the closed form. To express $a_5$ in terms of $\frac{1}{2}a_4$, we can either solve for $a_5$ directly or use the given recursion to obtain the desired expression.
brunette15
58
I have been given the following sequence: an+1 = an + (1/2)n+1, n>=0 with a0 = 1.
I am trying to express a5 in terms of 1/2(a4) .
I have started by writing out the first few terms however i am still struggling with getting a5.
Can anyone please help me out with this?
Thanks in advance!
What I would do here is find the closed form for $a_n$ first. Can you identify the homogeneous solution $h_n$ and the form of the particular solution $p_n$? If so, can you then find the particular solution and then by the principle of superposition give the general solution, and then use the given initial value to obtain the solution satisfying all given conditions?
Once you do this, then expressing $a_5$ as a function of $\frac{1}{2}a_4$ is straightforward. :D
Hi, thanks for the reply. I kind of see where you are heading with this, i am a bit unsure what you mean by closed form of an though?
When we find the closed form for the solution to a difference equation, we find (in this case) $a_n$ as a function of $n$. For example, if given:
\(\displaystyle a_n=a_{n-1}+n\) where $a_1=1$, then the closed form is:
\(\displaystyle a_n=\frac{n(n+1)}{2}\)
I will walk you through the process for finding the closed form for the given recursion, or difference equation:
\(\displaystyle a_{n+1}=a_{n}+\left(\frac{1}{2}\right)^{n+1}\) where $a_0=1$.
The associated homogeneous equation is:
\(\displaystyle a_{n+1}-a_{n}=0\)
Now, we see the characteristic equation is:
\(\displaystyle r-1=0\implies r=1\)
Thus we know the homogeneous solution is given by:
\(\displaystyle h_n=c_1\cdot1^n=c_1\)
Inspection of the original equation tells us the particular solution must have the form:
\(\displaystyle p_n=A\left(\frac{1}{2}\right)^n\)
We can now use the method of undetermined coefficnets to find $A$. Substituting this solution into the original equation, we obtain (after rearranging a bit):
\(\displaystyle p_{n+1}-p_{n}=\left(\frac{1}{2}\right)^{n+1}\)
Now, using the form of $p_n$, we get:
\(\displaystyle A\left(\frac{1}{2}\right)^{n+1}-A\left(\frac{1}{2}\right)^n=\left(\frac{1}{2}\right)^{n+1}\)
Multiplying though by $2^{n+1}\ne0$, there results:
\(\displaystyle A-2A=1\implies A=-1\)
And so, using the principle of superposition, we obtain the general solution:
\(\displaystyle a_n=h_n+p_n=c_1-\frac{1}{2^n}\)
Now, all that's left to do is find the parameter $c_1$ using the given initial value:
\(\displaystyle a_0=c_1-\frac{1}{2^0}=1\implies c_1=2\)
Hence, the closed form can be written as:
\(\displaystyle a_n=2-2^{-n}\)
So, can you now write $a_5$ as a function of $\dfrac{1}{2}a_4$?
Thankyou so much!
To finish up the problem, what I did was write:
\(\displaystyle a_5=2-2^{-5}\)
\(\displaystyle \frac{1}{2}a_4=\frac{1}{2}\left(2-2^{-4}\right)=1-2^{-5}\)
Now, if we solve both equations for $2^{-5}$ and equate the results, we obtain:
\(\displaystyle 2^{-5}=2-a_5=1-\frac{1}{2}a_4\)
And from this, by solving for $a_5$, we get:
\(\displaystyle a_5=\frac{1}{2}a_4+1\)
Another way to proceed would be to begin with the given recursion and compute the following values:
\(\displaystyle a_1=\frac{3}{2},\,a_2=\frac{7}{4},\,a_3=\frac{15}{8},\,a_4=\frac{31}{16}\)
Then use:
\(\displaystyle a_5=a_4+\frac{1}{32}=\frac{1}{2}a_4+\frac{1}{2}\cdot\frac{31}{16}+\frac{1}{32}=\frac{1}{2}a_4+1\)
It is also possible to say
a_{n+1}=a_n+\frac{1}{2^{n+1}}\implies a_5=a_4+\frac{1}{2^5}=2\frac{a_4}{2}+\frac{1}{2^5}.
FAQ: Finding a5 in an+1 Sequence Using a4 and 1/2
How can I find a5 in an+1 sequence using a4 and 1/2?
The formula for finding a5 in an+1 sequence using a4 and 1/2 is: a5 = a4 + 1/2.
What is the purpose of using a4 and 1/2 in this sequence?
a4 and 1/2 are used in the sequence to determine the value of a5, which is the fifth term in the sequence. This formula is based on the pattern of adding 1/2 to the previous term to get the next term in the sequence.
Can I use this formula for any sequence?
Yes, this formula can be used for any sequence where the pattern involves adding a constant value to the previous term to get the next term.
How many terms do I need to know in order to find a5 in this sequence?
You only need to know the value of a4 to find a5 in this sequence. However, knowing more terms can help you verify if the formula is correct.
Is there a general formula for finding any term in a sequence?
There are different formulas for finding different terms in a sequence, depending on the pattern followed by the sequence. In this case, the formula for finding a5 is specific to the pattern of adding 1/2 to the previous term.
