Finding $a_{50}$ with Coprime Constraints
  • MHB
  • Thread starter Albert1
  • Tags
    Constraints
In summary, finding $a_{50}$ with coprime constraints is a mathematical problem with practical applications in fields such as cryptography, coding theory, and signal processing. It involves using a formula that takes into account the coprime constraint, which limits the possible values of the sequence and makes the calculation of $a_{50}$ more efficient. Some real-world applications of this problem include secure communication systems, error-correcting codes, and efficient signal processing algorithms. However, there are challenges associated with finding $a_{50}$ with coprime constraints, such as time, computational resources, and the possibility of too restrictive constraints.
Albert1
1,221
given :
$a_1<a_2<a_3<--------<a_{50}$
$a_1,a_2,a_3,------,a_{50}\in N$
all $a_1,a_2,------,a_{50}$ are coprime with 987
that is $(a_n,987)=1 $
here $1\leq n\leq 50$
please find $a_{50}$
Mathematics news on Phys.org
I think you need to add a little more information, else the challenge is trivial - is $a_n$ intended to be the $n$th smallest integer coprime with 987? As described right now, $a_n = 987n + 1$ satisfies all your conditions.
yes ,$a_n$ is the $n$th smallest integer coprime with 987
and please find $a_{50}$
First we need to factor 987
987 = 3 * 329 = 3 * 7 * 47
to find a number which is coprime to 987 it should be co-prime to 3,7, and 47
now 1 is not coprime to any number so we need to find the 51st number which is not divisible by 3 7 or 47
for x the numbers below or same as not divisible by 3 7 and 47 are
$f(x) =x-\lfloor\dfrac{x}{3}\rfloor-\lfloor\dfrac{x}{7}\rfloor-\lfloor\dfrac{x}{47}\rfloor+\lfloor\dfrac{x}{3*7}\rfloor+\lfloor\dfrac{x}{3* 47}\rfloor+\lfloor\dfrac{x}{7*47}\rfloor- \lfloor\dfrac{x}{3 * 7 * 47}\rfloor$
or $f(x) =x-\lfloor\dfrac{x}{3}\rfloor-\lfloor\dfrac{x}{7}\rfloor-\lfloor\dfrac{x}{47}\rfloor+\lfloor\dfrac{x}{21}\rfloor+\lfloor\dfrac{x}{141}\rfloor+\lfloor\dfrac{x}{329}\rfloor- \lfloor\dfrac{x}{987}\rfloor$
or $f(x) =x-\lfloor\dfrac{x}{3}\rfloor-\lfloor\dfrac{x}{7}\rfloor+\lfloor\dfrac{x}{21}\rfloor-\lfloor\dfrac{x}{47}\rfloor+\lfloor\dfrac{x}{141}\rfloor+\lfloor\dfrac{x}{329}\rfloor- \lfloor\dfrac{x}{987}\rfloor$
for estimating we take $x-\dfrac{x}{3}=\dfrac{2x}{3}=51$ or x = 76 ( rounded)
so f (x) = 76 - 25 - 10 + 3 = 44
we are falling short by 7
so we add 14 as it is > 7 * 3/2
so we get x = 90 but as 90 is not coprime we take 89
f(89) = 89 - 29 - 12 + 4 - 1 = 51
so x = 89 is the ans.
$a_1=1$ should be included $a_{50}=88$
That is slight debatable as 1 is not coprime to any number so 1 should be left out. But if you want to consider 1 then you are right.
$987=3\times 7\times 47$
let :$a_{50}=x$
we have :
$\big[\dfrac{x}{3}\big]+[\dfrac{x}{7}]+[\dfrac{x}{47}]-[\dfrac{x}{21}]=x-50=38$
and we get :$ x=a_{50}=88$
FAQ: Finding $a_{50}$ with Coprime Constraints
What is the significance of finding $a_{50}$ with coprime constraints?
Finding $a_{50}$ with coprime constraints is a mathematical problem that has practical applications in fields such as cryptography, coding theory, and signal processing. It involves finding the value of a certain term in a sequence of numbers that are subject to the constraint of being coprime.
How is the value of $a_{50}$ calculated with coprime constraints?
The value of $a_{50}$ is calculated using a mathematical formula that takes into account the coprime constraint. This formula involves the use of modular arithmetic and the Euler's totient function, which calculates the number of positive integers that are coprime to a given number.
Why are coprime constraints important in this problem?
Coprime constraints are important in this problem because they provide a way to limit the possible values of the sequence, making the calculation of $a_{50}$ more efficient. Without this constraint, the number of possible values would be much larger, making it more difficult to find the desired value.
What are some real-world applications of finding $a_{50}$ with coprime constraints?
Some real-world applications of this problem include secure communication systems, error-correcting codes, and efficient signal processing algorithms. In these applications, finding the value of $a_{50}$ is essential for ensuring the security, accuracy, and efficiency of the systems.
Are there any challenges associated with finding $a_{50}$ with coprime constraints?
Yes, there are some challenges associated with this problem, such as the time and computational resources required to find the value of $a_{50}$. Additionally, the coprime constraint may limit the possible values too much, making it difficult to find a solution. However, with the proper techniques and algorithms, these challenges can be overcome.
