miniradman
- 196
We were presented with a task of calculating the temperature of absolute zero experimentally.
To do this, we were given a capillary tube with one end sealed. Then we heated the tube up in a bunsen burner and quickly put the open end in some cooking oil. The oil was sucked up as the gas within the tube cooled down. The result of this was that there was a small section of the tube filled with oil. (image of setup attatched)
Once we had out tube filled, we exposed them to 4 different temperatures (5oC, 25oC, 55oC and 90oC and measured (using a ruler) the length of the gas in between the oil and sealed end of the tube.
Once we had these points we graphed them to get a y=mx+c function. The only problem is that my c value (when the volume equals zero) is around -150oC. I've repeated the experiment 4 times with the same results and I don't know what is affecting the results so severly.
Any ideas would be greatly appreciated![Big Grin :biggrin: :biggrin:](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
