Finding acceleration from the angle made by a hanged ball.
In summary, a ball with a mass of 200g is attached to the roof of a moving bus with a rope at an angle of 18°. The ball will accelerate at the same rate as the bus since it is attached, and in the ground frame, someone would see the ball accelerating. To understand this, a free-body diagram can be drawn to calculate the forces acting on the ball. The air resistance can be ignored since it moves with the bus.
Mohamed BOUCHAKOUR
A ball with a mass of 200g, is hanged on the roof of a bus with a rope (it's mass is negligible), when the bus starts moving, the rope makes an angle of 18°.
What's the acceleration of the bus?
ΣF=m.a
The first thing i thought of is air friction, but it related to speed not acceleration, and the ball is inside the bus, it would be negligible.
Nothing exept that came to my mind.
You're right, air resistance is not an issue because the air moves with the bus. How about drawing a free body diagram?
ΣF=m.a
You can ignore the air resistance. Two questions:
What happens to something inside the bus that is attached to the bus?
What happens to something inside the bus that is not attached to the bus?
Yeah, but the only forces i can think of are gravity and rope.
If somthing is attached
If somthing is attached, it accelerate at the same rate as the bus.
And if it's not (ignoring friction) it would roll back.
But how does that help me?
Yes.
Is the ball in this case rolling back?
In a way yes(the 18° angle) , but then the rope prevents it from continuing,
What does that mean in the ground frame?
What does someone outside the bus see happen to the ball? Is it rolling/stationary/accelerating?
Accelerating
Accelerating
So now you know all the forces on the ball. Or, at least, can calculate them.
Still can't see it...
Have a think and draw a free-body diagram.
Likes Mohamed BOUCHAKOUR
I think I've got it, thanks for the help ✌✌
Related to Finding acceleration from the angle made by a hanged ball.
1. What is the formula for finding acceleration from the angle made by a hanged ball?
The formula for finding acceleration from the angle made by a hanged ball is a = g * tan(theta), where a is the acceleration, g is the acceleration due to gravity (9.8 m/s^2), and theta is the angle made by the hanged ball.
2. How do you measure the angle made by a hanged ball?
The angle made by a hanged ball can be measured using a protractor or a smartphone app with an inclinometer feature. Place the protractor or the smartphone on the same plane as the string or rope holding the ball, and measure the angle between the string and the vertical line.
3. Can the angle made by a hanged ball be negative?
No, the angle made by a hanged ball cannot be negative as it is measured from the vertical line.
4. What is the significance of finding acceleration from the angle made by a hanged ball?
Finding acceleration from the angle made by a hanged ball can help in determining the acceleration due to gravity and can also be used in experiments to study the motion of objects under the influence of gravity.
5. Are there any factors that can affect the accuracy of finding acceleration from the angle made by a hanged ball?
Yes, there are factors that can affect the accuracy of finding acceleration from the angle made by a hanged ball. These include air resistance, friction, and the precision of the angle measurement. It is important to minimize these factors to obtain an accurate result.
