Finding acceleration given mass and tension
In summary, if there is a 70N tension in a rope attached to a 4.0 kg bucket, the vertical acceleration of the bucket will be 9.8 m/s2.
Rionic
If there is a 70N tension in a rope attached to a 4.0 kg bucket, what will be the vertical acceleration of the bucket?
I'm not really sure how to do this. I can find tension but not acceleration. I think I'm missing something simple. I'm also confused about the direction because it doesn't state whether it is going up or down.
For the formula I got a=Ft-g and m+mg-Ft=a. Idk either are right
Where do those formulas come from? Their units do not match.
Did you draw a diagram with all relevant forces in it? That should always be the first step if you are unsure how to proceed.
I drew an FBD with Fg downwards and Ft upwards
If those are the only two forces on the bucket, what is the net force on the bucket?
What did your equation look like before you got this equation from it? It looks like you started out with the right equation but then made mistakes rearranging it.
You know, for example, that Ft = 70 N and g = 9.8 m/s2, but subtracting them doesn't make sense because they have different units.
Fnet=Ft-Fg then I turned fnet into ma and Fg into mg so it looked like
Ma=Ft-mg then rearranged it to a=Ft-g by dividing m on both sides
That should be a lower case m on the left ##ma = F_t - mg##
Now, when you divide the right hand side by m, what do you get again?
You mean,
##ma=F_t-mg##,
right?
Then dividing the left side by ##m## does give you ##a##, but you got the wrong result when you divided the right side by ##m##.
Who says that the rope is pulling upward on the bucket? How do we know that the rope isn't pulling downward on the bucket?
Chet
Mister T said:
You mean,
##ma=F_t-mg##,
right?
Doesn't the m on the right side cancel?
And maybe this question doesn't require a direction because it doesn't tell me if it's going upwards or downwards
Plug the numbers in and find out! Tell us the magnitude of each force, subtract them, and see if you get a net force that's equal to the mass times the acceleration.
There are two terms on the right hand side.
Ohh so it's a=Ft/m - g?
Yes!
Related to Finding acceleration given mass and tension
What is acceleration?
Acceleration is the rate at which an object changes its velocity over time. It is typically measured in meters per second squared (m/s^2).
How do you find acceleration?
To find acceleration, you can use the formula a = F/m, where a is acceleration, F is the force acting on the object, and m is the mass of the object. In this case, the force is the tension in the object.
What is the relation between acceleration, mass, and tension?
The acceleration of an object is directly proportional to the force acting on it (in this case, tension) and inversely proportional to its mass. This means that as tension increases, acceleration also increases, while as mass increases, acceleration decreases.
Can you find acceleration without knowing the tension?
No, you cannot find acceleration without knowing the tension. In order to use the formula a = F/m, you need to know both the force (tension) and the mass of the object.
How do you determine the direction of acceleration?
The direction of acceleration is determined by the direction of the net force acting on the object. If the net force is in the same direction as the object's velocity, the acceleration will be positive. If the net force is in the opposite direction, the acceleration will be negative.
