Finding acceleration through given equation
In summary, this student attempted to solve a homework equation but was not able to follow the steps correctly. They found the velocity and the acceleration at the first instant the car had zero velocity.
dlp211
The position of the front bumper of a test car under microprocessor control is given by:
x(t) = 2.17 + (4.80m/s^2)t^2 - (0.100 m/s^6)t^6
Find the acceleration at the first instant when the car has zero velocity.
0m/s^2, 4.8m/s^2
I know that the first instant that the car has zero velocity is at 2.17m at 0 seconds in time. I also know that the car is about to accelerate at this instant. I can't figure out how to determine what the acceleration is though.
How did you determine this?
delta x/delta t as t -> 0 is 2.17 (edit: this is wrong). It's because 2.17 is the starting point.
I don't know how to solve 2nd derivatives, I barely know anything about derivatives, our physics course is moving faster then our calc course right now.
In order to find the velocity as a function of time, you take the first derivative of the position. What does that give you?
Once you have the velocity as a function of time, how would you find the acceleration?
I thought that the derivative function would be 9.6t - .6t^5. But I haven't actually learned derivatives yet.
Good! That's v(t). And you can solve for the first value of t to make that zero.
Now find a(t).
Seems like you know enough to get through this problem.
so a(t) = 9.6 - 3.0t^4?
so a(t) = 9.6 m/s^2?
Right!
Yes, that's the acceleration at t = 0. Call it a(t = 0), not a(t).
Thanks for the help! My lectures go so fast and I have a hard time following all the formulas.
FAQ: Finding acceleration through given equation
What is acceleration?
Acceleration is the rate of change of an object's velocity over time. It is a vector quantity, meaning it has both magnitude and direction.
How do you calculate acceleration?
Acceleration can be calculated by dividing the change in velocity by the change in time. The formula for acceleration is a = (vf - vi)/t, where a is acceleration, vf is final velocity, vi is initial velocity, and t is time.
What is the difference between average acceleration and instantaneous acceleration?
Average acceleration is the total change in velocity over a specific period of time, while instantaneous acceleration is the acceleration at a specific moment in time. Average acceleration can be calculated by dividing the total change in velocity by the total change in time, while instantaneous acceleration can be calculated by taking the derivative of the velocity function.
Can you find acceleration through a given equation?
Yes, you can find acceleration through a given equation by rearranging the equation to solve for acceleration. The equation for acceleration, a = (vf - vi)/t, can be rearranged to solve for acceleration, a = (vf - vi)/t.
What is the unit of measurement for acceleration?
The unit of measurement for acceleration is meters per second squared (m/s²) in the metric system and feet per second squared (ft/s²) in the imperial system.
