Finding acceleration with ideal pulley
In summary, the upper block's acceleration is 2.1 m/s^2 when the coefficient of kinetic friction between the block and the table is 0.18, taking into account only the external forces acting on the system that are parallel to the motion.
David Mordigal
Two blocks are connected by a string as in the figure. (below)
What is the upper block's acceleration if the coefficient of kinetic friction between the block and the table is 0.18?
Express your answer to two significant figures and include the appropriate units.
F = ma
w = mg
Since this is an ideal pulley, the tension in each part of the string should be the same.
Let's call the tension in the string T. T should be equal in both parts of the string since this is an ideal pulley (we have not covered problems with friction in the pulley yet).
Since the upper block is not moving in the y direction, its net force in the y direction is 0. More specifically, its weight force is being balanced by its normal force, which are both 19.6 N.
w = mg = 2.0kg * 9.8 m/s2 = 19.6 N.
Since the weight of the lower block is acting on the string, the weight force of the lower block is the tension in the string because it is moving solely in the y direction.
Therefore, T = mg of lower block = 1.0 kg * 9.8 = 9.8 N.
Next, the upper block is moving solely in the x direction because its y forces sum to zero. Therefore:
Fx = max = T + (-fk).
We are given the coefficient of kinetic friction as 0.18, and since we know the normal force on the upper block to be 19.6 N, we can algebraically calculate the frictional force.
0.18 = fk / n --> fk = 3.53 N.
So, the sum of the forces in the x direction for the upper block = T + (-fk) = 9.8 N - 3.53 N = 6.27 N.
Using this value, we can algebraically solve for the upper block's acceleration:
F = max
max = 6.27 N.
(2.0 kg) * ax = 6.27 N
ax = 3.136 m/s2, rounded to 2 sig figs is 3.1.
The homework system says this is not the correct answer, so I don't know where to go from here.
Thanks for any guidance.
F = ma
w = mg
F = max
max = 6.27 N.
you didn't account for the fact that the lower hanging block is also accelerating, so T is not equal to mg. Draw free body diagrams for each block before solving.
F = ma
w = mg
This is not true. Both the weight and the tension act on the lower block and it accelerates, so the tension and the weight does not balance each other.
ehild
Try this:
Only use the external forces acting on the system that are parallel to the motion.
Only use the friction to the left and the weight of the 1kg mass. These are the only two forces that push/pull the system in its direction of motion.
(Weight 1kg) - (friction) = (total mass)a
(1kg*10m/s^2) - (.18*2kg*10 m/s^2) = (3kg)a
a = 2.133 m/s^2
Related to Finding acceleration with ideal pulley
1. What is a pulley and how does it work?
A pulley is a simple machine that consists of a grooved wheel with a rope or cable wrapped around it. It works by changing the direction of the force applied to it, making it easier to lift or move heavy objects.
2. What is an ideal pulley?
An ideal pulley is a theoretical concept in physics that assumes the pulley has no friction or mass. This means that all of the applied force will go towards accelerating the object, and there will be no loss of energy due to friction.
3. How can we find acceleration using an ideal pulley?
To find acceleration using an ideal pulley, we can use the equation a = F/m, where a is the acceleration, F is the force applied to the pulley, and m is the mass of the object being lifted. This assumes that the pulley is ideal and there is no friction.
4. What factors affect the acceleration of an object with an ideal pulley?
The acceleration of an object with an ideal pulley is affected by the force applied to the pulley, the mass of the object being lifted, and the angle of the rope or cable wrapped around the pulley. Friction and air resistance are not factors in this ideal scenario.
5. Can an ideal pulley be used in real-life situations?
No, an ideal pulley is a theoretical concept and cannot exist in real-life situations. In reality, there will always be some friction and mass in a pulley system, which will affect the acceleration of the object being lifted. However, ideal pulleys can be used as a simplifying assumption in physics problems to make calculations easier.
