Finding all subsets of a list of positive integers using backtracking
The discussion centers on a Python 3 solution for generating all subsets of a list of integers using backtracking. The provided code defines a `backtrack` function that recursively builds subsets by appending the current subset to a results list (`ans`) and iterating through the input list (`nums`). The function takes three parameters: the list of numbers, the starting index for iteration, and the current subset being constructed. The `subsets` function initiates the backtracking process by calling `backtrack` with the starting index set to 0 and an empty current subset. The output for the input list [1, 2, 3] is all possible subsets, including the empty set. To better understand the backtracking mechanism, users are encouraged to trace the code execution line by line, use print statements for debugging, or utilize debugging tools in an IDE. Additional resources, such as examples from Rosetta Code, are suggested for further learning about generating power sets in Python.
Andrew1235
The following Python 3 code is provided as the solution to this problem (https://leetcode.com/problems/subsets/solution/) that asks to find all subsets of a list of integers. For example, for the list below the output is [[], [1], [1, 2], [1, 2, 3], [1, 3], [2], [2, 3], [3]].
I am not familiar with backtracking. Can someone explain how the code works?
alist = [1,2,3]
ans = []
def backtrack(nums, start, curr):
ans.append(curr)
for i in range(start, len(nums)):
backtrack(nums, i+1, curr + [nums])
def subsets(nums):
backtrack(nums, 0, [])
return ans
print(subsets(alist))
Technology news on Phys.org
Python:
alist = [1,2,3]
ans = []
    ans.append(curr)
        backtrack(nums, i+1, curr + [nums[i]])
def subsets(nums):
    return ans
You need to put
Python:
[/color] before your code and
[/color] afterwards if you want it to be readable.
Python:
alist = [1,2,3]
ans = []
    ans.append(curr)
def subsets(nums):
    return ans
Likes jim mcnamara
The best (only?) way to understand it is to work through it line by line. You can do this on paper, or by inserting print statements in the code, or by using the 'watch' facitilty of an IDE and stepping through the code.
What pbuk said. At the very least, adding
Python:
print("backtrack called with)
print(" nums =",nums)
print(" start =",start)
print(" curr =",curr)
to the beginning of the backtrack function will show you how it's working through the data. First run it with a two element list, then a three element list, etcetera.
Thread 'Star maps using Blender'
Blender just recently dropped a new version, 4.5(with 5.0 on the horizon), and within it was a new feature for which I immediately thought of a use for. The new feature was a .csv importer for Geometry nodes. Geometry nodes are a method of modelling that uses a node tree to create 3D models which offers more flexibility than straight modeling does. The .csv importer node allows you to bring in a .csv file and use the data in it to control aspects of your model. So for example, if you...
I tried a web search "the loss of programming ", and found an article saying that all aspects of writing, developing, and testing software programs will one day all be handled through artificial intelligence. One must wonder then, who is responsible. WHO is responsible for any problems, bugs, deficiencies, or whatever malfunctions which the programs make their users endure? Things may work wrong however the "wrong" happens. AI needs to fix the problems for the users. Any way to...
I am trying to run an .ipynb file and have installed Miniconda as well as created an environment as such -conda create -n <env_name> python=3.7 ipykernel jupyter I am assuming this is successful as I can activate this environment via the anaconda prompt and following command -conda activate <env_name> Then I downloaded and installed VS code and I am trying to edit an .ipynb file. I want to select a kernel, via VS Code but when I press the button on the upper right corner I am greeted...
