Finding Amplitude of spring oscillation after damping
In summary, the time constant is 1/λ seconds and the amplitude decreases by 1/e of its original value after 84 oscillations.
AbigailG
[/B]
A spring with spring constant 10.5 N/m hangs from the ceiling. A 520 g ball is attached to the spring and allowed to come to rest. It is then pulled down 6.20 cm and released.
What is the time constant if the ball's amplitude has decreased to 2.70 cm after 60.0 oscillations?
[/B]
I used:
T= 2π√m/k
A(t) = A(0)e^-λt
-I apologize for the notation, still learning how to post...
[/B]
Plugging into the equation for T I found the period to be 1.398 s
After 60 oscillations 83.895 seconds will have passed
This is the t I used in the amplitude function.
The initial amplitude is 0.0062 m
The final amplitude is 0.0027 m
0.0027 = 0.0062e^-λt
.43548 = e^-λt
ln(.43548)=-λt
ln(.43548)=-λ(83.895)
0.0099=λ
The time constant is 1/λ = 100.921
This is where I ended up and it is obviously wrong...haha. Any help would be greatly appreciated.
Why is it so obvious that it is wrong? What are the units for the time constant that you found? How does it compare with the time required for 60 oscillations?
On edit: 6.20 cm are 0.062 m and 2.70 cm are 0.027 m. Here it makes no difference because the erroneous factor is on both sides and cancels, however you should not live your life believing this lest you make an erroneous calculation where there is no cancellation.
The units are seconds...i'm still not sure where I went wrong.
Without damping time < time with damping...Which seems to make sense because the spring is moving slower? Or would it take a longer amount of time for it to complete those oscillations...now I'm confused, I'm sorry.
I know it's wrong because when I enter it into Mastering Physics it's incorrect, haha.
The time constant is the time required for the amplitude to drop to ##1/e## of its value. Here, ##6.20~cm/e = 2.28~cm##. If the time constant is 100 s you would expect the amplitude after 84 s to be greater that 2.28 cm so 2.70 cm is perfectly reasonable. I got the same answer as you.
What does Mastering Physics say is the correct answer? Mastering Physics has been sometimes discovered to be incorrect, hahaha.
I wish I could tell you, but having a correct answer to work with would make things too easy, haha. I could click "give up" to find the answer but I don't want to lose the credit.
It seemed perfectly reasonable to me, it has to just be a simple mistake somewhere. Give it a shot if you're feeling ambitious! Haha, then we can compare, no pressure though. I appreciate your help thus far.
RedDelicious said:
The number of oscillations per second is given by the frequency. 1 oscillation is not the motion over 1 period.
[tex]\omega = 2\pi f
\\ f = \frac{1}{2 \pi} \sqrt{\frac{k}{m}} \approx 7.05 osc/s
\\~\\60osc / 7.05 osc/s \approx 8.5s
[/tex]
Ahh, I see. That makes sense. So now all I would have to do is plug the new time (8.5 s) into my my final equation? 8.5 seconds seems much to quick to complete 60 oscillations of such a large pendulum...or am I understand the 8.5 seconds incorrectly? I'm sorry, this is really giving me trouble.
No. Completely disregard that post. I made an error when I punched in the numbers. I redid it and got the same time.
Don't put another solution then. Show your solution to your instructor, who has control over Mastering Physics, and ask him/her why it's wrong. If you're right (which I think you are) you'll get the credit regardless of what Mastering Physics says. This may be one of the occasions when Mastering Physics is in error.
AbigailG said:
T= 2π√m/k
Doesn't the damping affect the period?
Okay I will. I have class tomorrow, I'll post an update tomorrow night. Thank you for your help!
Yes, that is taken into account with the equation A(t) = A(0)e^-λt
As I understand it, the time used in the Amplitude function is the time taken without damping, the equation yields the amplitude with damping, and with the data we have we can solve for λ. But I could be wrong.
How would you take into account the increase in the period due to damping when solving for the time constant?
Okay! I figured it out! The equation:
A(t) = A(0)e^-λt
was close...but not quite there, I looked further into my notes and found:
A(t) = A(0)e^-t/2tau
So...
0.0027 = 0.0062 e^-83.895/2(tau)
.43548 = e^-83.895/2(tau)
ln(.43548)=-(83.895/2tau)
tau = -83.895/2ln(.43548)
= 50.46 s
This is the correct answer.
Likes RedDelicious
Hi @AbigailG, I am sorry for misleading you. Like you, I assumed that the time constant τ is just the inverse of λ forgetting the "doubling" effect of the negative amplitudes, i.e. that the "natural clock" for the decay is the half-period rather than the full period.
Likes AbigailG
Fwiw, and in case this is not already clear, it turns out that although T= 2π√m/k is wrong here it is irrelevant.
The question is solved using the actual period, whatever it is. It is calculated from the 60 oscillation time and used directly to find the time constant.
(Specifically, the damped frequency is given by ##\omega_1^2=m/k-\frac 14\nu^2##, where the kinetic equation is ##m\ddot x+m\nu \dot x+kx=0##.)
Likes AbigailG
My blind spot was not in the solution; it was in not realizing that, in terms of the time constant, the equation of motion can be written as $$\ddot{x}+\frac{1}{\tau}\dot{x}+\omega_0^2x=0.$$It's not a form that is normally seen for the damped harmonic oscillator, but it makes sense in retrospect.
Related to Finding Amplitude of spring oscillation after damping
1. What is the formula for finding the amplitude of spring oscillation after damping?
The formula for finding the amplitude of spring oscillation after damping is A = A0 e-bt/2m, where A is the amplitude at time t, A0 is the initial amplitude, b is the damping constant, and m is the mass of the object attached to the spring.
2. How do you determine the damping constant for a spring?
The damping constant for a spring can be determined by dividing the natural logarithm of two consecutive amplitude measurements by the time elapsed between those measurements. It can also be calculated using the formula b = 2m(ln(An/An+1))/t, where An and An+1 are the amplitudes at two consecutive time intervals, and t is the time elapsed between those intervals.
3. Can the amplitude of spring oscillation after damping be negative?
Yes, the amplitude of spring oscillation after damping can be negative. This indicates that the object attached to the spring is moving in the opposite direction of its initial displacement.
4. What factors can affect the amplitude of spring oscillation after damping?
The amplitude of spring oscillation after damping can be affected by the initial amplitude, the damping constant, the mass of the object attached to the spring, and the time elapsed since the initial displacement.
5. How does the amplitude of spring oscillation change over time after damping?
The amplitude of spring oscillation decreases over time after damping. This is because the energy of the oscillating system is gradually dissipated due to the damping force.
