Finding an expression for the series
In summary, the true expression for the radius of convergence for the homework equation is (2n!x^(n))/((n!)^(2)) for n→∞.
Timebomb3750
59
1+2x+(4!x^(2))/((2!)^(2))+(6!x^(3))/((3!)^(2))+(8!x^(4))/((4!)^(2))+...
Uhhhhh...
Well, the denominator looks like it's going to be (n!)^2. And this expression appears to be using values of N≥0. But I'm not so sure as to what the numerator may look like.
Just going to import my answer over to here...
Char. Limit said:
No need to worry I figured out what you meant. The denominator is (n!)^2, like you said. The numerator isn't that hard, either, actually. Just think about what sequence goes 0!, 2!, 4!, 6!.
Yea. Sorry about the screw-up of the thread I made. Can't type today, I guess. But thanks. Makes since.
Alright. I think I got it. The true expression should be (2n!x^(n))/((n!)^(2))
That'll do it! Now just ratio-test that and simplify, simplify, simplify. You should get your answer before too long.
Uh, yea. Still not getting a radius of convergence of (1/4). Could be an error in the book, or I'm doing something wrong. I think I'll ask my professor about this tomorrow.
What DO you get? If you show your work, I'm sure I can help you.
Okay. I when I do the ratio test, it comes out to be the following...
(2(n+1)!x^(n+1))/((n+1)!^(2)) * (n!^(2))/(2n!x^(n))
this appears to equal...
(xn!)/((n+1)!)
But the limit of this as n→∞ equals zero. Still don't see how I'll get an answer of (1/4).
I think the problem is that you're seeing 2n! and 2(n+1)! as 2(n!) and 2((n+1)!), when you should be using (2n)! and (2(n+1))!. At least, that's the mistake the computer program I'm using to check my work is having. Fix that and you should be fine.
FAQ: Finding an expression for the series
What is the purpose of finding an expression for a series?
The purpose of finding an expression for a series is to simplify the representation of a series and make it easier to work with mathematically. It can also help to identify patterns and relationships within the series.
What is the process for finding an expression for a series?
The process for finding an expression for a series involves identifying the pattern or rule that governs the terms in the series, and then using mathematical operations and formulas to express the series in a simplified form.
What are some common types of series that can have expressions?
Some common types of series that can have expressions include arithmetic series, geometric series, and power series.
Can an expression be found for every series?
No, an expression cannot be found for every series. Some series may not have a consistent pattern or rule, making it difficult or impossible to find an expression for them.
What are the benefits of having an expression for a series?
Having an expression for a series can make it easier to perform mathematical operations on the series, such as finding the sum or product of the terms. It can also provide insights into the behavior and properties of the series.
