Finding an open-cicuit voltage, why is resistor in series ignored?
  • Thread starter Thread starter justin___
    Resistor Series
The discussion centers on understanding why a 30kOhm resistor in series is ignored when calculating open-circuit voltage, which is determined to be 200V. The key point is that because the circuit is open, no current flows through the resistor, resulting in no voltage drop across it. Consequently, the resistor does not affect the open-circuit voltage calculation. The clarification emphasizes the importance of current flow in determining voltage drop across resistors in series. This understanding is crucial for accurate circuit analysis.
justin___
The circuit you should use to find the open-circuit voltage, voc, is shown here. Note that the resistor to the right of terminals a and b has been removed to create the open circuit. Using any circuit analysis technique you like, find the open-circuit voltage.
KCL
I found how to get the solution to this question (the answer is 200V), but I don't understand why we ignore the 30kOhm resistor when using analysing the circuit. Because it is in series with the open voltage, wouldn't there be some voltage drop across the resistor that would affect the open-circuit voltage?
Thanks
Hint:
Can you write the equation for the voltage drop across a resistor given its value and the current thru it?
Upon inspection of that equation, the light bulb above your head will likely come on.
Cheers,
Tom
Tom.G said:
Hint:
Cheers,
Tom
Thanks for the hint. So because the 30kOhm resistor is in series with an open circuit, no current flows through it, therefore there is no voltage drop and we can ignore it from the equation?
Likes Tom.G and DaveE
Thread 'A bead-mass oscillatory system problem'
I can't figure out how to find the velocity of the particle at 37 degrees. Basically the bead moves with velocity towards right let's call it v1. The particle moves with some velocity v2. In frame of the bead, the particle is performing circular motion. So v of particle wrt bead would be perpendicular to the string. But how would I find the velocity of particle in ground frame? I tried using vectors to figure it out and the angle is coming out to be extremely long. One equation is by work...
