MHB Finding Angle ACB in Triangle ABC
  • Thread starter Thread starter Albert1
    Angle Triangle
In triangle ABC, with angle ABC measuring 45 degrees and point D on line segment BC such that 2BD equals CD and angle DAB is 15 degrees, the goal is to find angle ACB. A point M is identified between A and D where angle MBD equals 30 degrees, leading to the conclusion that AD equals the square root of 3 plus 1. The relationship between angles results in angle CMD being 90 degrees and angle MCA being 45 degrees. Ultimately, angle ACB is determined to be 75 degrees, confirmed by multiple participants in the discussion.
Albert1
$\triangle ABC , \angle ABC=45^o,\,\, point \,\, D\,\, on \,\, \,\overline{BC} $
$and,\,\, 2\overline{BD}=\overline{CD},\,\, \angle DAB=15^o$
$find :\,\, \angle ACB=?$
Mathematics news on Phys.org
Find a point $M$ between $A$ and $D$ such that $\angle MBD=30$. Note that $MD=DM$ and $AM=MB$. Say $BD=1$. The above leads to $AD=\sqrt 3 + 1$. Further note that $\angle CMD=90$ and hence $\angle MCA=45$. Consequently $\angle ACB=75$.
caffeinemachine :very good solution :cool:
Thanks. :) If you have a different one then please post it.
Albert said:
https://www.physicsforums.com/attachments/1209
from the diagram it is easy to see that :
$\angle ACB =30^o +45^o =75^o$
Awesome!
Thread 'Video on imaginary numbers and some queries'
Hi, I was watching the following video. I found some points confusing. Could you please help me to understand the gaps? Thanks, in advance! Question 1: Around 4:22, the video says the following. So for those mathematicians, negative numbers didn't exist. You could subtract, that is find the difference between two positive quantities, but you couldn't have a negative answer or negative coefficients. Mathematicians were so averse to negative numbers that there was no single quadratic...
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. In Dirac’s Principles of Quantum Mechanics published in 1930 he introduced a “convenient notation” he referred to as a “delta function” which he treated as a continuum analog to the discrete Kronecker delta. The Kronecker delta is simply the indexed components of the identity operator in matrix algebra Source: https://www.physicsforums.com/insights/what-exactly-is-diracs-delta-function/ by...
Thread 'Unit Circle Double Angle Derivations'
Here I made a terrible mistake of assuming this to be an equilateral triangle and set 2sinx=1 => x=pi/6. Although this did derive the double angle formulas it also led into a terrible mess trying to find all the combinations of sides. I must have been tired and just assumed 6x=180 and 2sinx=1. By that time, I was so mindset that I nearly scolded a person for even saying 90-x. I wonder if this is a case of biased observation that seeks to dis credit me like Jesus of Nazareth since in reality...
